Question about Fuji FinePix S5100 Digital Camera
Replace lens cap
Lost lens cap andhave to reoplace
Somewhere in the past aright handed lens cover has become lost. Need another.
Not sure about the reference to 'right-handed' lens cover - most of them have a spring clip for the filter threads. To get a lens cap, just look on eBay for one that has the same internal diameter as the filter threads on the lens - this is usually marked on the lens, as in 49mm, 52mm etc.
Oct 20, 2017 | Cameras
Can't get Casio Futurist into vibrate mode since reoplacing the battery. The "VIB" area on the watch won't flash for me to adjust the setting. Am i doing something wrong or simply goin
2 things you could have the back on wrong way or you've lost the small coil spring that touches the back plate of the watch that give you the vibration ,,
Nov 22, 2014 | Casio Futurist Mens Vibrating Alarm Watch...
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
I lost the lens cap for my wide angle lens on my Maxxum 7000. Are they available and if so, where can I get one?
I don't know which wideangle lens you have, but there most likely is a number giving the the size of the thread in front of the lens. If there isn't, you can measure it with a ruler marked in millimeters. Either way, simply order a lens cap of that size online or buy it at a good camera store. If you can't find the size, simply take the lens with you to a camera store and find a lens cap that fits. You don't need to find a specific brand, about the only thing that matters is the size. Unless, that is, you care a whole lot about the styling...
Jul 08, 2010 | Minolta Maxxum 7000 35mm SLR Camera
CANON XL LENS CAP FOR 16X ZOOM LENS
According to its specifications, this lens can use a 72mm filter. So you should be able to get the type lens cap that clips into a 72mm filter to work. Such as the one shown here. I'd recommend you go to a local camera store and try one to make sure it works.
Feb 11, 2009 | Canon XL1S Mini DV Digital Camcorder
Lost lens cap
http://www.bitssite.com/canon-powershot-pro-1/2827/rear-lens-cap/accessory.html
That should be the cap your looking for if not let me know. Please take a moment to rate my solution fixya if it helps.
Thank you,
Lee
Jan 04, 2009 | Canon PowerShot Pro1 Digital Camera
Lens Caps
try...15165474200 or 1800 645 6678...hope this
Nov 26, 2007 | Nikon Travelite V Binocular
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Sep 18, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
Fuji FinePix S5100 Digital Camera Logo
26 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
