Question about Canon PowerShot Cameras
How do I get the spring out to put new door in?
SOURCE: Powershot A430 canon camera battery problem
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Aug 29, 2008
SOURCE: my canon powershot A550 camera behaves as low battery with new b
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
SOURCE: My Canon PowerShot A570 IS won't turn on. I put
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on May 19, 2010
SOURCE: Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Posted on Aug 15, 2010
SOURCE: Instruction manual for canon powershot
Hi!
Download it from here... Scroll down and select your desired language.
Regards,
Pelu.
Posted on Sep 18, 2010
Jan 06, 2017 | Building Materials
Jun 10, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Mar 13, 2015 | 2003 Chevrolet Tahoe
Sep 18, 2014 | Building Materials
Apr 02, 2014 | 2000 GMC Jimmy
Nov 07, 2013 | Cars & Trucks
Aug 12, 2009 | Whirlpool AWM6120 Front Load Washer
Mar 13, 2009 | liftmaster Chamberlain Garage Door Opener...
Dec 05, 2008 | 2001 Oldsmobile Bravada
Mar 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
123 people viewed this question
