my guess it does this only cold block. right. a key fact.
glow plugs failing
just because a lamp come on , dont mean much,
actual glow plug current is what matters. (proper)
only takes 3 things
proper compression.
glow plugs
fuel.
there's a possibility that your battery is bad. and if you want to check that you have a known good ac adapter. here are the steps that you can try.
1. turn off the laptop. (shut it down properly). 2. remove the battery and disconnect the charger. 3. plug in the charger without the battery. 4. power on the laptop.
note: if it comes on normally. it means, that your charger works fine. from that point, you could isolate if it's a battery or a charger issue.
You have a problem with the LCD cable. It ussually happens when the LCD cable is pinched off at some point, causing the screen flickering. You can buy a new LCD cable from eBay, they are cheap, and it's easy to replace-just unplug the old one, and plug the new one.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
you should have 2 batteries with it ...take battery out put other one in making sure in correctly seated...plug into pc via usb see if charging icon comes on ...once enough charge in to startup phone try other battery ...when charging you can press and hold top button on phone to startup if enough power...
maybe it's just the T.V I mean the N64 is like 10+ years old and you're trying to get it to work in a new T.V! I reckon that your best bet is to buy an older T.V to play it with or get an emulator e.g PJ64 on your computer and then you can still play your games
there is a slot behind the screen when you push open the screen should drop down. put the cd into that slot when you do the screen will go back up. push open again the screen will drop and your cd will eject automatically.
hi i juz bougth my new sonyericsson j220i and i want to decode it but it is not respondin to the software on the internet when i connect to the net with the cable
