Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
How to switch to standard mode from economy mode
My Dream maker Odyssey spa is stuck on economy mode. There is no way for me to see to change it to standard mode.
Try pressing 'TEMP' then 'LIGHT'. You may have to do this a couple of times.
If you don't have a 'TEMP' button, either the temperature up or down will also work.
There are three modes, ECONOMY (EC / ECO / ECON), SLEEP (SL / SLP) and STANDARD (ST / STD). For everyday use keep it on STANDARD mode.
Cheers,
Ian Kime
Ian Kime Hot Tub Sales Repairs and Servicing
May 02, 2017 | Standard Pool & Spa
I have an EC display on my panel
That means your "Heating" mode is in Economy! Without knowing what make our model spa you have, or the manufacturer of spa controls, difficult to assist in telling you how to switch to other modes. Maybe try this:
Pressing the "Temperature" button and then immediately the "Light/Jets" button may change the system back to Standard? Once you press those buttons, the "Ec" code comes on and stays on (flashing), and then you can press the "Light/Jets" button to toggle between Standard and Economy and maybe SL - which is Sleep modes.
Good luck
Feb 22, 2015 | Pool & Spa
I can't get my beachcomber 350 out of economy mode, cannot get the heater on.
If you are pushing the buttons in the correct sequence to switch modes from economy, standard, sleep, vacation, etc. (all systems have different modes and different sequence of buttons to push, to change this) then your topside control panel could be bad, or the circuit board.
good luck
Oct 12, 2014 | Pool & Spa
How do you get it off economy mode
there is a MODE/PROG button on the panel. this buttom switches the unit between the modes.
Press it and it will cycle thru from Standard to economy.
It's on page 5 of the manual... and you can download it from http://www.qcaspas.com/content/pdf/Majestic-10Btn.pdf if this is your unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Jun 29, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Apr 06, 2013 | Washing Machines
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
Mar 13, 2013 | Balboa Instruments Pool & Spa
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
In econ mode my 1998 spaform hot tub does not appear to heat but it is ok in standard mode.
in the economy mode it will only maintain a temperature so that it will not freeze. Economy mode is mostly for vacation time or for winter if you are not going to be using the hot tub for an extended period of time.
Put it into the standard mode and you will be able to have a HOT tub and will function as it should
US Parts Center
Aug 22, 2011 | Pool & Spa
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
257 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Tom Chichester
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
