Belling XOU492 Electric Double Oven Logo
Question about Belling XOU492 Electric Double Oven
Beko oven fan catching element everything secure making dreadful row
Anonymous
I had the same problem. I believe it’s because the screw bracket On the element behind the shield is a few millimetres out. I solved this by removing the screw and gently twisting the element until it sat centrally around the fan. Took several attempts to get it right and there’s a possibility the element may break if you’re heavy handed. The only option I could think of was redrilling a small hole above the existing one to accept the self tapping screw but we’re only talking a couple of millimetres.
Posted on Jun 05, 2019
Andy Brown
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
Are you sure the fan is touching the element?
In experience it will be a noisy fan motor or bearing.
Posted on May 20, 2019
  • Ismail Patel
    Ismail Patel May 20, 2019
    Yes it is touching as fan is marked where it is touching
Michael
    New Friend:
  • 4 Answers
Your oven must be fairly level for the fan not to make a noise.
Posted on Jun 29, 2014
1 Related Answer
Anonymous
  • 123 Answers
SOURCE: no fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Posted on Aug 27, 2009
Beko built in oven fan makes a noise like it's catching on something, now the fan has stopped
you will need to change the motor
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 • Ovens
2answers
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 • Ovens
1helpful
2answers
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 • Ovens
11helpful
2answers
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 • Ovens
My bottom fan oven isn't heating up, the fan is working though, for model Beko DVC6531
The element has blown, you will need to replace it (should only cost
Aug 09, 2010 • Ovens
3helpful
2answers
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 • Ovens
2answers
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
Jan 14, 2010 • Ovens
1helpful
2answers
No fan or heat
regards Sir Galahad
1helpful
2answers
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 • Ovens
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
