Question about Windchaser PAC9 Air Conditioner
What causes the exhaust hose to get hot on a windchaser portable AC
It throws cold air but the window hose gets so hot the it heats up the room what causes a w what causes a Portable Windchaser air conditioner window hose to get so hot it starts to heat up the room from the heat of the window exhaust hose.It ggets so hot that you have to turn the machine off because it starts to heat up the room
Walter Raymond II
    Sergeant:
  • 191 Answers
Make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Posted on Jun 29, 2014
3 Related Answers
Anonymous
  • 22 Answers
SOURCE: Portable Air conditioner is not starting and then stopping.
Empty the water out of the collection pan? This will shut the unit down to keep it from ruining your floors. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
Anonymous
  • 30 Answers
SOURCE: Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Posted on Oct 12, 2009
carl riggins
  • 70 Answers
SOURCE: I need an exhaust hose
You and get flex duct at lowes 6" 25' to a box that should work the same, In the heating cooling section.
Posted on Aug 28, 2010
I have a portable model# MPPH08CRN1B10 I don't know if it as cold as it should be. Should it be blowing really hot air out the exhaust?
yes
that is how ac units work \By removing the hot inside and blowing it out thenexhaust
being portable it is best to have the exhaust going out a window or have it placed in a door way to prevent the hot air recycling
Jun 22, 2018 | Heating & Cooling
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
I have a PACRWC-HP. We only use it for short periods during Seattle summers. Now in it's third year, it does not evaporate the water filling the small overload every hour. Can it be fixed or should...
Jerry, Windchaser has been out of business for about 5 or 6 months. So, if it requires parts to fix the problem, it will difficult to find them. But, before you properly scrap the unit, check several of the things, that may be causing the problem.
1. The air intake filter may be dirty or clogged. Remove and clean thoroughly, if necessary.
2. The exhaust hose may be drooping from the unit to the window outlet. This allows condensation
to accumulate in the hose, rather than exhaust out the window.
3. Obstruction in exhaust hose will cause the same thing as in # 2. Remove the hose check & clear
any obstructions, as necessary.
I hope this has helped you troubleshoot, find and solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | Windchaser Portable Air Conditioner
Do i have to vent this ac pacr10 wind chaser
Yes, it definitely requires venting via an exhaust hose(s) (flexible duct) connected to a window converter.
Aug 14, 2011 | Windchaser PACR10 Portable Air Conditioner
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
I want all cold air it blows hot out the back why
the back should blow out hot and at the front it blows out hot
the hot is the air in your room
Jul 22, 2011 | Heating & Cooling
Unit shuts off, getting an E5 error. sounds like there is a lot of water inside. the customer service numbers for Windchaser are disconnected. PLEASE HELP!!!!
E5 is the fault code for Compressor overheat/malfunction it coulb be caused by the exhaust hose being too long or kinked, remove the exhaust hose and run the unit for an hour and see if your problem goes away, if so re-route the exhaust hose, if not you need to contact the manufacture
Jul 22, 2011 | Windchaser PACR10 Portable Air Conditioner
I need an exhaust hose for a Windchaser 9000 portable ac with remote
Aug 28, 2010 | Windchaser PAC9 Air Conditioner
Everstar MPK CR10, blows cold, but won't cycle.
Make sure the exhaust hose isn't longer than the maximum allowed and is not kinked, turned too many times (bends) and is the right diameter as specified in the manual. It sounds like the unit is going off on high head pressure.
If at all possible, change the exhaust hose to a smooth type rather than the corrogated hose that probably came with the unit. The less air restriction in the exhaust the better.
Seal any air leaks at the exhaust or discharge point.
Aug 23, 2009 | Heating & Cooling
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Windchaser PAC9 Air Conditioner Logo
241 people viewed this question
Top Windchaser Heating & Cooling Experts
Marvin
Marvin
Dennis Boxerman
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
