Question about SanDisk 2GB microSD Memory Card
Memory password how can i know phone memory password?
I forgot my memory card password , what is the solution?
This is what I did to unlock a memory card password in my nokia phone. You can try it in yours First is you unlock the phone
      1. Turn off the phone and insert the memory card into the memory card slot. Turn the phone back on.Press the "Menu" button on the main screen and click on the option for "Extras."
      2. Scroll down to the bottom of the list. Click the selection for "Memory Card."
      3. Select the "Options" icon on the screen. Scroll through the list to the "Unlock Memory Card" option and press "OK."
      4. Type in the unlock password in the password field. If you do not know the password, the default unlock code is either "12345" or "1357."
        • Delete the Memory Card Password
      1. Turn off the phone and insert the memory card into the memory card slot. Turn the phone back on.Press the "Menu" button on the main screen and click on the option for "Fun & Apps."
      2. Navigate to the option for "Gallery" and click on the "OK" button. Scroll to the "Memory Card" item and then click on "Options." Scroll to "Memory Card."
      3. Click "Delete Password" when the window prompt appears. Make sure the message "Memory card will be unlocked, do you want to continue" appears. Click on the option for "Yes" to confirm.
      4. Scroll down to the password field and enter in the default password. If you do not know the password, the default unlock code is either "12345" or "1357." Click "OK" to delete the password from being required.
Jan 01, 2011 | Nokia 5800 XpressMusic Smartphone
Sir i forgot my password for micro sd memory card .i couldnt format it.pls solvve
MEMORY CARD PASSWORD.
you can use this link to Know about password memory.
(wiki.answers.com/Q/How_do_you_remove_micro_sd_password).
Take care.
Jun 19, 2010 | Nokia N93 Cellular Phone
I forgot the password in the memory card
Take care.
Jun 24, 2010 | Nokia 3120 Cellular Phone
Unlocking my memory card for lost password
Sad to tell you this, once a memory card has been password lock and you don't know anymore the password, you cannot recover anymore your memory card. But you can try your luck, find a memory card password recovery software for your phone. Click this link http://www.esnips.com/doc/6977e741-249e-4869-b21e-4859917bf883/Unlock-MMC--Password
Install the software in your phone and use it.
Nov 10, 2009 | Nokia 6300 Cellular Phone
How to fix my cp when the phone memory has a password???????????
If you mean the phone memory is locked with a password, then the only answer is to get the firmware reinstalled. While if you mean the memory card, then format the memory card. You would loose all data but that is a small price to pay for a lost password.
Aug 28, 2009 | Nokia 5310 Cellular Phone
How to Unlock N70 Password.
try 12345 is a standard code for nokia
Dec 31, 2008 | Nokia N70 Cellular Phone
Memory Card
Dear
First u should know:---
1. All Nokia Phone save the memory card password in its phone memory.
2. Card Password is saved in Memory*.dat file on phone memory.
Now the process to know ur password
1. if u have file explorer in ur phone, search the above file and transfer it to PC
2. or U can use MobiMB Mobile Media Browser to get this file
3. In pc u open that file with Notepad. U see ur password.
Most easy trick to remove card password:--
In Market A card password removing device is available at 200 Rs. It is operate by 9 volt battery or USB.
It is also a card reader. U can remove password from all types of memory card from this device.
I think it is a good device for all also have value of money.
Oct 20, 2008 | Nokia 3110 Cellular Phone
Password forgotten nokia n73 memory card
After restore setting know My Nokia N73 Memory card is on Password and I am not forget my Memory card password help me
Jul 22, 2008 | Nokia N73 Cellular Phone
Memoru card password
I had purchased a Nokia 6233 recently. I want to change the password to access memory card but it asks for Old password.
I do not know the old password... I am able to access the memory card.
Jun 25, 2008 | Nokia 6233 Cellular Phone
SanDisk 2GB microSD Memory Card Logo
47 people viewed this question
Top SanDisk Electronics - Others Experts
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Ekse
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
