Question about JVC KD-HR60
How do I set my stations I'm asking the question over and over...where is the help?
Posted by Crystal... on
william rodriguez
  • 958 Answers
Just call jvc or go to their web site for answers
Posted on Jun 29, 2014
Unable to get stations 3-5 to work on my irrigation controller
Include product model and brand when asking question so we can access manual and review possible causes
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 16, 2014 | Hardware & Accessories
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
Does tuning stations in a dvd/vhs change the tv settings?
no, it will not change your tv settings. because your only tuning the stations of your lgv271. so don't hesitate on tuning your lg v271.
if you have any questions, just ask me.
Jan 14, 2012 | LG V271 DVD Player/VCR
Following the instructions for pre-setting radio stations, having practically no success. When I try to select a station number the tuning is lost.
When you preset the station, you usually have to press and hold the number you want to set it to until the stereo set makes a noise signifying it has set the channel.
Hope this helps :D
Anymore questions, just ask.
Nov 23, 2010 | Audio Players & Recorders
New 2010 Hyundai Elantra handbook describes several different radios but not the one in the car I just bought. Looking for information on how to set up choice of stations
if the car is that new it's generally best to ask the dealer as it sounds like that stereo is a dealer add on item. that said most stereos that have push buttons to chose stations are set by tuning in the station and then holding in the button you want to use to select that station for a moment or two.... until the station you have tuned appears. that station is now selected by that button.
Jan 10, 2010 | Car Audio & Video
Change ringing station to station
There is only 3 beeps when you call the station because it is set in th privacy mode (HTP) on bottom of phone. Change it to T for tone. Any further, don't hesitate to ask. If this don't work, let me know.
Feb 13, 2009 | Vodavi IP7024LD Corded Phone
Cannot figure out how to set favourite radio stations on my Clok
I just spoke to tech support. They said not being able to set the radio station to 96.1 is a PCA hardware problem. They asked me to get the product exchanged.
Dec 25, 2008 | Digital Products International Clok Smooth...
Help with storing radio stations
Ergh, you might want to explain what KIND of system it is if you need help!
Usually if you have a PRESET button on your system, just tune to the station you want, hold the preset button and it will save the station...or ask you which slot to use (use fast forward/rewind or any other arrow key to change the slot) and viola! And if you have numbers (like in a car for example) just tune to the station and press and hold (for example) the 1 button and it will store the station.
Hope it helps a bit.
Sep 16, 2008 | Audio Players & Recorders
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
JVC KD-HR60 Logo
41 people viewed this question
Top JVC Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Jim Pattison
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
