Question about Fuji FinePix S5200 / S5600 Digital Camera
How to remove lens from FUJIFILM S6500 LENS - Fuji FinePix S5200 / S5600 Digital Camera
5 Related Answers
Anonymous
  • 274 Answers
SOURCE: s6500fd,s6500 lens types.
The lens is a 28-300mm zoom and is permanently affixed to the camera (s6500fd).
The only extras are listed here:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/d-slr-long-zoom/finepix-s6500fd/OptionalExtras
Posted on Dec 13, 2007
Anonymous
SOURCE: fujifilm a820 not working
fixed mine by connecting it to the computer and thretoning it with a software upgrade.It just came right .
Posted on Dec 30, 2008
Anonymous
  • 691 Answers
SOURCE: Lens control error
Hello
Thank you for using FixYa for your problem
Sorry but the Zoom Lens has had a knock, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 22, 2009
david
  • 244 Answers
SOURCE: whiteout on fujifilm f20. how do I remove the lens?
Firstly, to isolate the shutter as the problem, turn the camera on and the flash off. put the lens into full optical (not digital) zoom. Then turn the camera lens to face you and look at the lens and take a picture.
With the camera in full optical zoom the shutter assembly will be right up to the outer lens so you can see it clearly. When the button is pressed you should see the shutter fire across the lens inside. It should cover the lens completely. If it does not or doesn't fire at all then you get over exposed pictures or lines across the photo. The most likely cause for this is moisture residue on the shutter leafs sticking them together.
To clean you will need to strip the lens down almost completely to access the shutter assembly. If this model of camera uses a sealed shutter unit then it will be impossible to clean. The only models i have found so far that use a sealed unit are the F460 and F470. Yours I am not sure of as I haven't opened 1 up but the solution for most is to strip it down and clean.
Tip: use another camera to photograph each stage to help on re assembly
Posted on Jan 18, 2010
Yogesh Kshatriya
  • 1040 Answers
SOURCE: I keep getting a lens control error on my FujiFilm
Sorry Friend, it is a mechanical problem so get it serviced.......
Posted on May 08, 2010
Can anyone tell me how to remove lens from fujifilm hs 20
You can't remove the lens of your not so cheap bridge camera.
If you want to clean the lens, it really needs to stay on. After removing anything on or from this lens, you need at least a collimator, to align the lens elements. If not it won't be able to focus and could give lots or other errors in the pictures, like colour blur, aberration and out of focus parts.
Jan 14, 2015 | FUJIFILM HS20 EXR Digital Camera
Re Fuji finepix, keep getting message turn off camera, turn on again as lens won't extend, so camera not useable, batteries fresh. any ideas? thanks, robin
Remove and reinsert the batteries or disconnect and reconnect the AC power adapter/DC coupler. If the problem persists, contact your FUJIFILM dealer.
Before that:
Carefully check if and eventualy where the lens is blocked. Don't touch the front lens. Feeling for any movement on the edge not on the glass. If there is not any obstruction, then perhaps the motor that should move the lens is defect. If you can find anything that blocks the lens, ask a technician if he / she can remove is. Or else I'm affraid you have to visit your FUJIFILM dealer.
Oct 31, 2013 | Fujifilm Finepix S2980
I recently purchased a Fujifilm Finepix Hs20EXR Camera. Is the zoom lens removable and if so, how do you remove it?
The lens is NOT removable. It's a Bridge camera. If you did manage to remove it, you'd break the seal and allow dust, etc into the camera body. Besides, you cannot fit a different lens anyway, so why bother?
eVAPor8
Jan 06, 2012 | FUJIFILM HS20 EXR Digital Camera
Can i change the lens of my camera model Fujifilm FinePix HS10
While you may not be able to remove the fixed lens on this camera, you can still add other lenses on top of it, like a telephoto or wide angle lens. An example of lens accessories you may purchase for this model can be found here.
Mar 25, 2011 | FUJIFILM FinePix HS10 / HS11 Digital...
How do I remove the lens from my fujifilm finepix s1500 and i want to get a wide lens how can I modafi my camera to be able to swich to diffrent lens or do they make lens for this kind of camera?.plz help.
Your camera is a point-and-shoot camera styled to look like a DSLR. Your lens does not come off. If you want interchangeable lenses, you need to step up to a DSLR camera.
Jan 13, 2011 | FUJIFILM Finepix S1500fd Digital Camera
Black screen on my s6500 fd
I assume you removed the lens cap...;-)
If both the viewfinder and the screen is black, it is most likely an error on the CCD. If the viewfinder is OK, but the screen is dead, the problem is probably the LCD.
Hopefully you still have warranty on the camera?
Oct 02, 2009 | Fujitsu Cameras
S6500fd,s6500 lens types.
Dec 13, 2007 | Fuji FinePix S6500 Digital Camera
Fuji s6500 different lenses
any type of filter of anybrand, also any type/brand of teleconverters can be use with s6500 as long as it's 58mm
Attachments?
There are loads of lenses on ebay such as 58mm 0.45X Wide Lens FOR Fuji S6000 S6500 fd BKs.gif I think any will work provided they are 58mm
Nov 14, 2007 | Fuji FinePix S6500 Digital Camera
F-Stop
You can download the manual from the link below: http://www.fujifilm.co.uk/digital/cameras/s6500/index.php?page=brochures In aperture priority mode on page 65 you will see that the maximum F number is F8. To set F11 you need to put the camera in manual mode, then you can go to F11. This assumes you are using the standard Fuji lens. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Fuji FinePix S6500 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
