Question about Summit SPWD1800 Laundry : Washer/Dryer Combos
Dryer will not work any more, keeps flashing error13 message
The dryer will start but no heat goes to the tub, instead the top of the machine gets hot and after 15 minutes the errormessage comes on and machine stops
2 Related Answers
SOURCE: dryer proplem
Rather than try to give you answers, I'm giving you this online link that COULD lead you to a solution: http://appliantology.org/topic/42011-washer-dryer-combo-error-code-er13-haier-summit-ariston/
I looked at it for a few minutes and answers are up and down between encouragement and discouragement. One suggestion is a bad thermostat at the top of the unit, but I'm not sure if you'll be successful in locating replacement parts according to some of the things I glanced at. Hope this helps.
Posted on Jun 28, 2014
daimaxboyce
Dai Boyce
  • 288 Answers
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores.
Posted on Nov 15, 2014
Dryer proplem
Jun 28, 2014 | Summit SPWD1800 24" Washer/Dryer Combo...
Took apart the washer and dryer and need to put it back together...i have everything except where the clear plastic hose goes
Kristen-follow the hoses-water comes into machine at the water supply valves-hot and cold which go into the tub-then there is a drain pump which is connected to the tub via a hose-the out put of the drain pump is connected to the drain through the back of the machine usually at the bottom and this goes into your houses' drain-follow the hoses and you shall reach laundry success-cheers Denny
Oct 25, 2013 | Frigidaire FEX831CS Top Load Stacked...
Dryer is running but the dryer will not dry and the air is cold instead of hot
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 13, 2011 | Frigidaire FGX831F Top Load Stacked Washer...
Lgq9858pw dryer. Clothes would come out damp and cold. I replaced 2 thermostats (?) in the rear of the unit, located on the heat shield. The clothes now come out warm, not hot, but still damp. Any ideas?
if you popped the high limit thermostat that usuallt pops when the dryer needs to be cleaned out.pull out the lint filter,unplug the dryer,remove the two phillips screws in front of the filter,go in the back,remove the vent line remove the back panel and remove the duct that the lint filter slides into and clean it out,if you can't remove the duct push it to the right and vac out the blower wheel and pull the duct out towards you so you can get the vac into the duct to clean it,also if you have a brush you can brush all the lint down to the bottom and vac it up.if the vent line is a long run to the outside i use a leaf blower to blow out the vent line,go outside first and make sure the vent is clear so the lint will blow outside.one or both of these sound like it's blocked with lint or you can also have bad gas coils.the coils work for the first 15 to 30 minutes and stop working when they heat up.after they cool down they will work again until they get hot.you can start the dryer,pull off the plastic cover on the left side so you can see the flame ignite,watch the flame lite,after 15 to 30 minutes go back and look into the hole,if the flame isn't liting you know the coils are failing.easy fix,unplug the dryer,the coils are on top of the gas valve,remove the two pillips screws,remove the cover and replace the coils,part number 279834 and they are around 20 dollars,you get both coils instead of getting them separate.you should clean the dryer once every year so the dryer runs like it should,clothes drying on time,your parts will last longer and you don't have to worry about any lint fires
May 04, 2011 | Dryers
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Cold dryer
if the dryer runs normal for the first 15 to 30 minutes you have bad gas coils located on the top of the gas valve,take out the 2 phillips screws,remove the top cover and change out the gas coils.when the coils are failing they will work until they heat up then they stop letting the gas come into the dryer,when they cool down then they will work again.change out the gas coils part number 279834
Mar 27, 2010 | Kenmore 73952 Gas Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Summit SPWD1800 Laundry : Washer/Dryer Combos Logo
85 people viewed this question
Top Summit Washing Machines Experts
ray gallant
Dai Boyce
Dai Boyce
 Russ Hill
Russ Hill
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
