Computers & Internet Logo
A
Anonymous Posted on Jun 28, 2014
How to factory reset macbook pro - Computers & Internet
vpitman1
Level 2:
Scholar:
New Friend:
  • Expert 59 Answers
  • Posted on Jul 20, 2014
vpitman1
Expert
Level 2:
Scholar:
New Friend:
Answers
59
Questions
0
Helped
15780
Points
126
There's no real reset, though you can reset many basic settings by opening the System Preferences. However, in certain situations, you may want to zap the PRAM or NVRAM. You do this by turning off the computer and holding down the option, command, P, and R keys before the Apple logo appears (usually while the screen is still grey). The computer will chime (loudly) and begin the startup sequence again. This is useful for resetting certain basic settings and to help recover from a kernel panic (a type of crash that can cause problems again on restart).
http://support.apple.com/kb/ht1379
1 Related Answer
Anonymous
  • 31 Answers
  • Posted on Aug 06, 2012
SOURCE: I would like to restore my MacBook back to its factory settings, like when it comes out of the box
If you have an OS X installation DVD, you can go through the installation process and will be given the option to do a fresh install.
Firmware password forgoten
This is from the Internet and could be fake news:
What year MacBook Pro is it? If it is a 2011 or 2012, then you are out of luck. If it is older than that, then remove one stick of RAM or, if you only have one, add a stick, then reset the PRAM three times.
1helpful
How do i factory reset a macbookpro 2013model
Here is a discussion running on the Apple site: How do wipe and reset your Macbook Pro Retina to Factory
You also find links how to safe sell your MAC.
And here is a Youtube video how to reset without disks.
How to reset your MacBook Pro to Factory Settings without Installation...
Success
Factory reset button on macbook pro
There is no 'Factory Reset' button as such. If you are running OS 10.7 to 10.10, then you need to start up from the 'recovery' partition (CMD+R) on startup. You will then be able to erase the hard drive using 'Disk Utility' and then re-install the OS.
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
4answers
How to put my mac book pro back to factory settings without reinistall disc
Use Disk Utility to erase the hard drive. ... The process of resetting a Mac or MacBook tofactory settings gets rid of all your data ... This cloned drive can be re-cloned back to the main drive if you decide to restore your Mac, or it can be used to ... This means it will no longer be linked to your iTunes account. MacBook supportnumber 1 800 726 0294 Apple Technical Help
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Grand Canyon Tech
Grand Canyon Tech
