Pioneer PD-F407 25-Disc CD Changer Logo
A
Anonymous Posted on Jun 28, 2014
Why does the display only show "01"? - Pioneer PD-F407 25-Disc CD Changer
Bosch SHE3AR75UC/08 E:01 After A Lightning Strike
Contact Bosch direct, we aren't they.
You need a service call and an engineer with a laptop.
Bosch dishwasher error code e 01 If a Bosch dishwasher displays the error code e01, it means the control panel is malfunctioning. ... If the dishwasher does not work at all or fails, the faulty control board is probably the case. It controls all the functions.
Bosch dishwasher error code e01
https://bosch-dishwasher-errors.com > bosch-dishwasher-e...
Search for:
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
9helpful
5answers
I need restriction code for my x2-01
You can get the Nokia X2-01 Restriction code from the site Onlinegsmunlock.com/unlock-your-phone/rs7wp2/ and Unlock it easily...
1helpful
3answers
How do i reprogram my speeddial numbers on jazz 4400?
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Hotpoint ultima wt741p is showing F:01 on the display screen when the machine starts up -the machine starts but no water comes through and the drum stays idle - any advice please ????
F:01 is display say some error problem occur in your machine, maybe the motor that pump water to fill the machine has not working or its sensor that water is flowing is not working also.
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Error E:01:00
I have had the same problem with my camera. After some years without any reason the message E:01:01 appears on the screen and the display shows only black.
I dissamble the camera, clean all contacts and after assembling the camers does works as before.
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
