Question about Sanyo Office Equipment & Supplies
Sanyo firmware download
No audio on hdmi 1,2,3. ther is dvi audio on hdmi/dvi 1 and comp video3 audio input. hdim input only sees input of dviim looking for firmware update
Posted by joe dally on
5 Related Answers
Anonymous
  • 167 Answers
SOURCE: infocus screenplay 4805 not communicating with PS3 console.
Try pressing the "auto image" button on the projector itself. This sometimes solves these types of problems.
Posted on Nov 29, 2009
Anonymous
  • 21 Answers
SOURCE: I would like to connect my Sanyo PLV-Z2 project to
I have the same unit (2 of them actually.) I have spent a lot of time on this very issue. The problem is that although the unit is "supposed" to be HDCP (digital copy protection) compatible, it is not fully. I've found that with some DVD players it will work for a minute or two and then go black, and with others, it will flash on and off, and with some it will never do anything but black. I have only found 2 ways around this. 1 is to use a computer (which does not use the HDCP) windows Vista/windows7 might have the same problems, but XP/2000/Linux work perfectly. The other solution that worked was to use a Playstation3 which seems to work perfectly with it playing DVDs and BlueRays.
Posted on Mar 10, 2010
Anonymous
  • 12 Answers
SOURCE: Connecting Projector to High Def Source (e.g. PS3 HDMI)
That projector supports M1-D also which is the digital side of the M1-DA... Anyway, they sell cables that are M1-D to HDMI to which you can hook directly to the PS3. They are decently priced too, less than $20. I know this thread is old, but I came across it due to an issue I am having with my xb31, broken color wheel. Trying to find parts...
Posted on Jan 02, 2011
RyanFanMan
Ryan Nguyen
  • 342 Answers
SOURCE: mt1065 NEC projector HDMI to DVI adapter no
did you buy that adapter from radio shack if so then return it and look at somewhere like staples or best buy they can help you
yhjack99
Jack
SOURCE: DVI-HDMI not working with Sanyo Z2
Well, I found these cables that says that they have HDCP. I just ordered them to see if they will solve the issue of old projectors not having hdcp.
Posted on May 07, 2012
When i try to play my x box on my sanyo tv no sound comes out of the tv
Try a different HDMI input and a different cable.
DVI is same as HDMI in regards to the picture signal, but lacks the audio.
Apparently for some reason the TV does not pick up audio and that could be because the HDMI port has a problem (say physical contact) or because the cable has a problem or (of course) because the XBOX does not output signal for some reason.
My first two picks would be the port and the cable.
hope this helps!
www.coppelltvrepair.com
Oct 08, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Cant get audio to go on hdmi intput 1 via dvi to hdmi
dvi does not have audio out. if your are hooking a computer to an hdtv you will need a cord from the sound card to an amp. Or if your t.v. has vga in you can use that and the pc audio input. It is a cord and each end has a standard 3.5mm headphone jack on it.
Jun 10, 2011 | Sanyo 42 in. LCD TV
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
Problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Feb 25, 2010 | Sanyo DP50747 50 in. Plasma TV
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Can i use tv as computer screen
The same VGA cable you would use to connect it to a computer monitor.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 29, 2009 | Sanyo DP42848 LCD TV
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
HDMI
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Oct 15, 2007 | RCA P52926 52" Rear Projection Television
85 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
