Question about Zanussi FJS1225W Front Load Washer
Washer whilst washing keeps flashing up with E90
Washing machine keeps flashing up with E90 and occasionally hesitating when washing cant find manual please can advise
Posted by stefo on
  • 1 more comment
  • Anonymous Mar 19, 2014
    went to do a washing today set the machine to specific setting and it flashed F-1
  • Anonymous Mar 20, 2014
    Unscrewed filter cap whilst washer was running it caused machine to stop and 2 red lights started continually flashing.
  • Anonymous Mar 24, 2014
    eror e90 what shall i do
prem mathew
    President:
  • 1,294 Answers
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Posted on Jan 01, 2008
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    It is flashing E90
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem, may be a power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed.
    Good luck.
    Jun 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
    Machine flashing E90 and not working.
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
    Jan 16, 2011 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    Washing machine displaying E90 error
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Dec 12, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    Electrolux 1087 E90
    call frigidaire for factory service or have the dealer replace it
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    E90 Error Code
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Zanussi FJS1225W Front Load Washer Logo
    501 people viewed this question
    Top Zanussi Washing Machines Experts
    peter gittos
    peter gittos
    Marvin
    Marvin
    Fundi mnoma
    Level 1 Expert
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
