SOURCE: RCA 52 inch TV
My tv will not turn on the light comes on three times then stops till I try it again.
SOURCE: Intermittent vertical jitter.
These sets have a PIP module which is plugged into main board and has a brown ground wire to the can.Surface mount caps c7001 and c7036 are usually the problem but if the capacitors have leaked too much you may never recover the board,CURE eliminate PIP by putting 10 mfd 50v cap from pin 5 to 11 and another from pin 9 to 7 on the VP plug under the main PCB
SOURCE: KP-41S4U TV
THe standby light will blink a code that should be a repeating code. Please post the count here as that indicates which circuit has the fault. That info coupled with the model number above will allow us to explain what is broken and perhaps what parts need to be changed to fix it.
Dan
SOURCE: green timer light blinking constantly, no picture
Your TV might have the symtoms of defective capacitors in the DM board.
Click here or here to find more info on how to DIY.
Good Luck.
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
