SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll
need to keep running it untill it runs clear and it uses alot of your
ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
SOURCE: Can't install, fails every time.
had this same problem, go to Add and Remove Programs and uninstall "Bonjour" and then run the Kodak Setup and it will reinstall it.
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
