SOURCE: The belt slides to one side (the same side) always
you need to tighten the w/belt. the side that the belt goes to tighten 3 quarter turns. now on the other side loosen 2 quarter turns. turn on the the belt on 3or 4 setting the belt should start moving over when it get to where you want it tighten the sid e you first loosen 2 quarter turn. then run it at higher speed to see if it stays its trial and error remember rightie tightie leftty loosie. in the end you want equal tension with the rollers bolts ps good tension is 2 -3 inches up when lifting up the sides of the w/belt
SOURCE: The belt is squeaking on my Spirit xt10 treadmill.
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
SOURCE: what type of lube is used to lube walking belt
use 100% silicone LUBe buy it from www.fitnessrepairparts.com and lube every week of use, Otherwise you will have nightmare of trouble.
God bless you
see the videos and proceed according. God bless you
SOURCE: What kind of lube should be used for the bearings and walking belt of a proform 625 treadmill?
1) for deck belt use 100% silicone LUBE
2) for bearing use WD-40 Or similar.
God bless you
