Question about Magic Chef MCBR445S1 Stainless Steel Compact Refrigerator
Magic chef mcbr4455s1 will not take freon
Installed piercing valve on pigtail but the unit will not accept freon.
1 Related Answer
David Jewell
  • 454 Answers
SOURCE: chipping away ice in magic chef freezer section i
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Posted on Feb 06, 2010
3 way valve charging procedure
On the data plate there is the amount of freon and it's type. Usually F22. There is a tube connected to the compressor that looks like it's going no where. You need a piercing valve to attach to this tube. Evacuate the system for several hours. Add the freon. Use a pinch off tool to close off the tube between the piercing valve and the compressor. Remove the valve and use an acetylene torch and silver solder to close the end of the tube, NO other type of solder besides silphos is acceptable. Remove the pinch off tool and turn on the refriferator
Aug 08, 2015 | Refrigerators
Magic chef mcbr175b needs freon how to put it in
You will need a technician to do this probbaly but you can buy a self piercing fitting that you can install on the freon line and thne if you have the equipment you can add freon to the system this way.
Sep 12, 2014 | Magic Chef Refrigerators
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
CAN I ADD FREON TO A QHIRLPOOL WINDOW AIR CONDITIONER UNIT MODEL ACE184XS0
yes you can but you will probably have to put service ports on it as most window a/c do not come with them .The easy way to do this is to get a couple of self tap saddle valves that all you have to do is back off piercing point out of the way while you clamp the valve around refridgerant lines and tighten screws down evenly. Follow directions and make sure you use the right size spacers for the line size you have. When you have the valve properly placed and secured then screw piercing point down thru the copper and close all the way. Attach gauges to servicevalves and open valves to check freon pressure. Add freon as needed. Thank you.
Jun 01, 2011 | Whirlpool Electronic Window Air...
Need to add 'freon' to my samsung window unit.
Hello, in order to add freon to a window unit you must add a piercing valve to then low side of the system. The valve mounts to the suction line and allows you to connect your gauges and add freon. Here is a link to where you can purchase piering valves. http://www.hvacr-tools.com/mm5/merchant.mvc?Screen=PROD&Store_Code=HVACR&Product_Code=BPV31&Category_Code=VALVES
May 30, 2011 | Samsung Heating & Cooling
My Magic Chef chest freezer stopped cooling, slowly, over two weeks. I emptied, unplugged, defrosted, cleaned coils, and powered up again. Red light is on, won't cool. Guessing freon or compressor...
Sounds like slow Freon leak. You might get an estimate over the phone before calling a technician, but I would think a 3-year old box is worth repairing. If the estimate is close to the replacement cost, that might not be the case.
Feb 25, 2018 | Magic Chef Chest Freezer MCCF5WBX
How do I add freon to my hailer portable
you proably do need a piercing valve as those units usualy have no acces to the refrigerant. be carefull on how you do that the best way is to braze a fitting on and pull a vacuum then charge. most piercing valves will end up leaking on you down the road
Jun 13, 2009 | Haier HPAC9M Air Conditioner
Hole
you have punctured one or more of the refrigerant lines. Your chances of fixing this are slim, but if you can find the hole, you can solder it shut, then pressurize the unit with new refrigerant. The former you might be able to do yourself. The latter will require you to get a repairman who has the necessary refrigerent and valves to re-load the unit. I would guess the cost of repair is probably more than the unit is worth.
Feb 08, 2009 | Magic Chef MCBR170 Compact Refrigerator
Magic chef- apartment size
The unit is sealed most tecks will not recharge to small to deal with. Most common cause for this is low freon. If someone has a clamp on amp meter the wire leading to the compressor will probibly show very low amps. showing a free flow compressor. Cheaper to replace.
Oct 23, 2007 | Magic Chef CTF2125 Top Freezer...
Magic Chef MCBR445S1 Stainless Steel Compact Refrigerator Logo
51 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
