Texas Instruments TI-30XA Calculator Logo
Question about Texas Instruments TI-30XA Calculator
How do I use TI-30XA to solve normalcdf problem?
How to use normalcdf function
5 Related Answers
pmore006
SOURCE: trig functions of the TI-30XA
if the sides of a triangle are 15cm ,16cm, and 17 cm ,then the area of the triangle is what ?
Posted on Jun 16, 2008
Anonymous
  • 43 Answers
SOURCE: TI-30XA user manual
Nope, there's a download online at TI's website but it's the same as the one that comes with the calculator.
Posted on Dec 31, 2008
Anonymous
  • 43 Answers
SOURCE: TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
Anonymous
  • 10865 Answers
SOURCE: my texas instruments ti-30Xa doesn't turn on!
It has a solar battery. It has to be in the light, either sun light or artificial light to operate. HOWEVER, if the battery is shot, it must be replaced. Take your calculator to any radio shack store and ask them to test the battery for you. If it is no good, they will be able to replace it for a fee.
Posted on Aug 03, 2009
Anonymous
  • 30 Answers
SOURCE: simplifying fractions on the TI-30XA
Two ways:
1) hit the equal sign
2) hit 2nd and [d/c] (you can do this multiple times to see it as the most reduced improper fraction or as a mixed fraction)
Posted on Sep 29, 2009
How to solve graphing equations
How can you graph equations (functions) if you do not have a graphing calculator?
Finding normalcdf function on TI-30x
Sorry, the TI-30x doesn't have the cumulative normal probability function built-in.
2helpful
2answers
2nd vars 2 (normalcdf( -999999,-.1923) Just trying to get area from z value -.0.1923 keep getting errors
The normalcdf function takes three arguments: the z value, the mean, and the standard deviation. In the "standard" case the mean is 0 and the standard deviation is 1. Thus, try calculating
normalcdf(-.1923, 0, 1) .
Okay so i am using a TI-30XA What is the button on this calculator for (Prb) ??
There is no probability key on the 30Xa as there is on the 30XIIS. The shifted functions of the 8 and 9 keys will calculate the number of combinations and permutations, respectively. The shifted function of the 3 key will calculate the factorial. There is no random number generator.
2answers
How do i solve 10^-4.80 on my TI-30XA
You would type in 10 [y^x] 4 [.] 80 [ moz-screenshot.pngkarmahm.png ] [=] . This should make the 4.80 negative.
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
3helpful
Can I do numbers squared on this calculator, and how would I enter this?
The TI-30XA is a scientific calculator with many functions. You can calculate problems with fractions and decimals, as well as solve problems of probability and functions. A scientific calculator computes the number sentence you type in using the order of operations: parentheses first, then roots and exponents, then division and multiplication and, finally, addition and subtraction.
How to Use a TI-30XA
  • Step 1Press the [ON/C] key to turn on the calculator. Press the [OFF] key to turn it off. To use the calculator in solar mode, put the solar panel in the light and then press the [ON/C] key. To turn it off when in solar mode, slide the calculator cover back on and it will automatically shut off.
  • Step 2Replace the batteries by first removing the cover and placing it face down. Use a Phillips-head screwdriver to unscrew the back panel. Remove the back panel and change the batteries. Screw the back panel back on. Press [OFF] [ON/C] and [ON/C].
  • 0helpful
    Percentage function
    Pick up the small instruction booklet here and look at page 4, the "%" key has 4 functions...
    http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
    1helpful
    3answers
    Trig functions of the TI-30XA
    1helpful
    2answers
    Variables
    The TI-30XA cannot solve algebraic equations. You need a more advanced calculator for that, like the TI-89.
    Regards,
    javabytes
    Top Texas Instruments Office Equipment & Supplies Experts
    Filipe Polido
    Filipe Polido
    Muzahura Frank
    Paul Bade
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
