Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
18.5 hp lawn tractor will not turn over when on compression stroke . If you move it a little by hand past compression stroke it will start.
Jason Patterson
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Sounds to me that you have a weak battery and is not putting out enough cranking amps..Takes more cranking amps during compression strokes to start than in down stroke...That is why you are able to start it in the down stroke less amps needed to turn motor over..
Posted on Aug 09, 2014
5 Related Answers
wadembly
Wade Mobley
  • 513 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
Anonymous
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
Anonymous
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
paul nielsen
  • 252 Answers
SOURCE: Craftsman lawn tractor, LT2000, 18
hi there
here is web site for manual and parts diagram
http://www.hammerwall.com/Download_Manual/12377/
have the valves been adjusted correctly ? or could have a tight valve clearance
and when gets warm holds valve open - looses power
your engine will be 31p777 intek ohv avs
run the piston to tdc on compression stroke , then turn piston past tdc & set piston is 1/4 inch down the bore on power stroke this eliminates decomprssor lift from the setting
intake should be 0.003 Thou
and exhaust 0.005t thou
then check the carburettor main jets and emulsion tube and pilot jets and air bleeds and progression ports for obstruction etc for restriction / blockage
check fuel flow from tank to carb , check that the fuel solenoid has got continual 12 volt supply
when switched on and does not go o/c cutting fuel supply to main jet
have a look let me know
cheers hope it helps
pauly 46
dont forget the thumbs rating
Posted on Jun 09, 2011
jbiggs8150
JOHNNY B.
  • 14 Answers
SOURCE: craftsman lawn tractor 917.271060w/kohler 15.5 hp
VALVE LASH NEEDS ADJUSTED AND CHECK ROCKER ARM BOLTS FOR TIGHTNESS. CONSULT KOHLER FOR PROPER TORQUE ON BOLT AND VALVE CLEARANCE BEFORE CRANKING UP ENGINE.
Posted on Oct 13, 2012
Jd#la115 does not turn over past compression stroke
I'm guessing a "weak battery" is the problem. Sometimes a fresh new battery can make a piece of equipment run "like new"..... Also, you might make sure battery is high enough capacity... If all this does you no good, I'd guess you have a "tired" or worn out starter...
Nov 19, 2013 | Garden
Craftsman lawn tractor, LT2000, 18 HP OHV INTEK, 917.273752 I have a similar stalling problem as the one I reviewed in your forum, 10-15 minute run time, then stalls. Only difference, no cool down...
hi there
pauly 46
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
21 hp electric start Craftsman lawn tractor, B&...
Have your mechanic set your intake/exhaust valves at .004 when piston is 1/4 inch past top dead center on compression stroke.
May 19, 2010 | Garden
Cub Cadet LT1050 lawn tractor won't turn over and start. Starter motor does turn, but flywheel doesn't turn very fast, and stalls each revolution at the top of the compression stroke. I can turn the...
three people i know plus myself have this same problem with this same model tractor. new starters and new batteries did not help any of us
May 06, 2010 | Garden
Starter get hot engine won't start. When I remove the spark plug and put the plug back in the wire and crank it I can see the spark but when I put the plug back in and try to crank. It won't crank very...
You likely need to get the valves adjusted,it sounds like the decompressor is not working.You need to get the compression down to 130 lbs while cranking or the starter can't overcome the compression.Try turning the motor past the compression stroke by hand and see if it will crank faster,if so then the decompressor is out of adjustment.If the decompressor is not just a lob on the valves then you need to call the repair depot for craftsman and find out what you need to do to fix the problem.If none of the above works then you may need a battery,or just clean the cables and battery posts.
Apr 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp, Starter will engage, will not go past the compression stroke. Checked valve clearance, it is fine. Mechanic says it's probably not the starter. HELP?!
I'm not sure of the engine in your machine but i can tell you that all small gas engines have some sort of de-compressor,be it on the cam or a simple" bump" on the camshaft.It sounds like yours is not working.Some briggs engines need the valves adjusted until there is only 120lbs of compression during cranking to aid in starting,when it does start the compression will go back to normal as it comes off that "bump" with engine rpm.Check with your dealer for the proper adjustment of the de-compressor.
Mar 23, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a turfmaster 16.5 hp 42"....left the deck engaged when I turned it off now it won't start after it is disengaged. It trys to turn over, but won't.
The deck engage is not the problem here. If it were related, the engine would not even try. The valves need adjustment to compensate for wear on the "internal compression release" located on the camshaft. This is normal wear.
To "get by" for now, you can turn the flywheel by hand (in a clockwise direction) until it is just beyond the compression stroke and the starter should start it just fine, provided the rest of the machine is healthy.
PLEASE NOTE: this procedure for starting is masking the REAL issue and the valves will need routine adjustment as soon as feasible.
If you are handy with tools, know the internal workings remotely, and wish to explore, reply with a request and I will explain the valve adjustment procedure in detail for you.
Hope this helps,
Dolf-
Oct 13, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
141 people viewed this question
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
