Question edited for spelling.
Question moved from Cars and Trucks to GE Refrigerator.
You need a service call to replace the sealing gasket. The whining is probably the fan at the back of the drawer. If the knocking is the compressor, the fridge likely needs a refrigeration gas top up.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
scroll down and look into the other responses,. there may be some similar one to yours where you will find a better answer than I can give you now. Best regards, Ck
I replaced the fan module under the glovebox on my 2005 Town & Country last night. Mine would not shut off at all with key on. It only blew on high no matter where I set the switch. Mine also had the climate control which makes a difference. If it is not the auto climate control it is usually the blower resistor if the other fan speed selections don't blow at all except on high.
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace. This is the cold zone fan which supplies cold air to the meat and crisper drawers.
check for fuse compartament and look under cluster controls or interior climate controls see if any of them are burn out, check for blower fan and test motor or replace motor.
You must check the evaporator fan motor in the freezer.
Is it running?
You may need to push the door switch with the freezer door open for fan to run with drawer open.
Next check the damper in the fresh food section.
Is it open?
Air circulating through?
If not, replace your damper control and thermistor.
This fridge is garbage. Fixed ours 14 times in 6 years. WILL NEVER BUY ANOTHER MAYTAG ANYTHING AGAIN!!!! CLIMATE ZONE TECHNOLOGY DRAWERS NEVER DID WORK CORRECTLY....EVER.
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
