SOURCE: my kenmore frontload dryer won't turn on; its
check circuit breakers/fuses located in house supply panel.
SOURCE: kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
SOURCE: I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
If you have questions, please let me know. I hope this helps you.
SOURCE: kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
