Question about Chevrolet 1996 Chevrolet S10/s15/sonoma Radio
Where is fuel pressure Schrader valve on S10 pickup
Would like to check pressure
Posted by Michael Wilson on
Rob Duron
  • 55 Answers
On my S10 blazer I believe it was on the fuel rail or just back from the fuel rail on top of the engine. If you start at the injectors and follow the fuel line back you should find it pretty quick.
Posted on Jun 28, 2014
  • Ralph Koozer Jul 23, 2014
    Depends upon the model of engine. In GM's imitation multiort fuel injection found on some of these it is under the hat of the fuel injector cover with the injection tubes, check the book for your model of engine, year, vin # etc.
Joel Friedenberg
    Genius:
  • 1,114 Answers
Troubleshooting the Fuel Pump GM 4 3L 5 0L 5 7L
Look on the fuel rail that connects to the injectors.
How to fix the fuel pressure if it is the problem with my car not starting
Usually there is a check valve in in near the fuel pressure regulator on the fuel rail. There is a schrader valve you can hook up a fuel pressure guage to test on the regulator too.
Nov 02, 2014 | 1A Auto Parts 1999 Chevy S10 Blazer GM...
How to test to make sure fuel pump is getting power
You could check for fuel pressure at the injection rail assembly, especially if there is a Schrader valve on the rail. The Schrader valve looks like an air valve and operates the same way. Push in on the valve stem to see if fuel comes out under pressure. Have rags around the valve to catch the gas. Best is to attach a pressure gauge to the valve, and then you can read the pressure. Possibly Auto Zone or Advance will the gauge as a loaner. This will comfirm the fuel pump is working and providing the correct pressure.
May 26, 2014 | 2002 Chevrolet S-10
Location of fuel pressure test valve
Not sure about what engine you have, but here is the general procedure.
Open the hood. Disconnect the negative battery cable from the battery.
Look on the front of the engine and find the fuel rail. The fuel pressure regulator is on the right side of the fuel rail. Follow the fuel lines toward the firewall until you come to a Schrader valve with a black cap. Rotate the cap counterclockwise and remove it from the valve.
Wrap a shop rag around a small flat-head screwdriver and press the center pin in the Schrader valve - you have relieved fuel pressure when no more fuel comes from the valve. Install the cap back onto the Schrader valve. Hope that helps.
Apr 05, 2014 | 1999 Pontiac Sunfire
How to test fuel pump delivery module on 98 tracer
you will need a fuel pressure gauge remove schrader valve cap on fuel rail under hood then screw the fuel pressure gauge to schrader valve use a rag around fitting to catch fuel spill.when you check fuel pressure just turn on ignition few seconds dont start engine just turn on ignition just to build up fuel pressure.
Sep 21, 2013 | 1998 Mercury Tracer
Gas not getting to schrader but pumping in 96 s10 truck
Check fuel pressure regulator make sure vacuum connection is attached and it has vacuum also many of these vehicles have plastic fuel lines make sure the fuel line is not crimped or crushed forward of the fuel filter
Mar 26, 2013 | 1A Auto Parts 1996 Chevy S10 Pickup GM...
My 2000 chevy S10 wont start I changed the battery and it ran fine for 2 days now it will turn over but won't start
Check Fuel Pressure. First turn key to on position (without starting) and listen for the fuel pump motor. If no motor sound, your fuel pump is not working. Check fuel pump fuse and relay. If fuel pump works, check for pressure at the fuel rail (schrader valve on fuel rail for pressure testing). If no pressure, or not enough, fuel filter might be clogged or fuel pressure regulator may not be working properly. IF fuel is not the problem, start checking electrical, such as ignition control and proper spark to plugs.
Aug 14, 2010 | 2000 Chevrolet S-10
Where is the Schrader valve on a ford Explorer 1995 V6
I believe the schrader valve for checking your fuel pressure can be seen looking from the passenger side of the engine. It is on the fuel rail, which is installed between your lower and upper intake manifold sections, about the center of the fuel rail.
Hope helps (remember rated this) Good luck.
Feb 02, 2010 | 1995 Ford Explorer
How to release fuel pressure to replace fuel filter on a buick rendevouz 2004
if you open up the hood and find your fuel rail you should see a little cap just like what is on your tire valve stems. take the cap off and push the little valve in the center agian just like the valve stem on your tire. be vary carefull as fuel will spray out of this. that is how to depressurize the fuel system
Jul 29, 2009 | Buick Rendezvous Cars & Trucks
1987 chevy S10 engine idle problem
relace the throtle air idle valve.The temp switch will allso cause this problem.
Jul 19, 2009 | 1987 Chevrolet S-10 Pickup
Is there any way to test the injectors on my 98 chevy S10 4.3
DID you put in new gas, fuel treatment, new sock on fuel pump, all new fuel filters, buy inline fuel pressure gauge, check for codes?, this is not a carb where you pour fuel at it , do you have a repair manual for your truck and have you checked troubleshooting guide?
Mar 22, 2009 | 1998 Chevrolet S-10 Pickup
Chevrolet 1996 Chevrolet S10/s15/sonoma Radio Logo
1,149 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
