There are 2 different ways to delete an App on iPhone/iPad:
1) - Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner.
that's it.
2) - For devices running iOS 5 and later, there is also another way to do this:
hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space is helpful when you're trying to install new apps, You may even notice apps that have a lot of storage attached to them that you weren't even aware of before
SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: My WritePad app for IPAD no longer separates
If the spacebar on the keyboard isn't there (with .com and underscore keys etc instead), you're in the URL-typing keyboard instead of the normal one. Try clicking the @ icon in the bar just above the keyboard to change modes. In handwriting mode, it's the same thing...click the @ icon near the left side of the bottom bar.
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
SOURCE: How do I sync my old iPad apps to new ipad?
You can use a itransfer to transfer files from iPad to the New iPad.
and this one can help you successfully transfer media files among all iOS devices, back up to PC
and iTunes, shift from iTunes and PC library to iOS devices, manage
media sources without iTunes.
