Question about Magellan Roadmate 760 GPS Receiver
How to reset magellan roadmate 5145t-lm
After an update, an electrical spike occurred and the USB icon image connection between the unit and the computer appeared on the screen witch dimmed after 2 sec. When power is recycled Mitac screen appears and after 2,3 sec it goes back to the USB connection image. How can I reset to boot into regular program. Checked with a computer if files are on the drive, and found that they are there.?
4 Related Answers
Anonymous
  • 86 Answers
SOURCE: Temperature below safe level warning when starting GPS
Ahh yes the ever so elusive temp. below safe level error. lol. (sorry) Attached to the radio board are 3 wires connecting to the top of your lcd. This is where the temp is read from. I know telling you this doesn't help, just info. This problem has been fixed from swapping out radio boards (the board that's behind your keypad), additionally swapping out hard drives. I'm not sure if the unit will detect the USB but, if you can, try re-loading whichever version you have ie. 4.32/5.14. As far as end user fixes, I don't exactly have one unless you can find a scrap unit that someone doesn't want b/c it's malfunctioned as well. Good luck and I wish I could of been more help. -Dan
Posted on Sep 24, 2006
Anonymous
SOURCE: Magellan Maestro 3250 wont power
Hi, as I have been in the situtaion with many electronic devices before I know how frustraing it can be when the car charger doesn't work any more. For every one out there reading this post if this happen to you again take the car charger portion that you put in the lighter for a charge, the part the goes in will unscrew, check the fuse. 99% of the time that fuse has blown and that is the cause of the unit not getting a charge, if replacing the fuse does not work the it is a bad unit and you will have to get another gps.
Posted on Mar 18, 2010
KingDWS
Dave King
  • 1606 Answers
SOURCE: I was trying to update
Look in your manual on how to do a hard reset. Usually is holding the power button/slide on while resetting. That can get it out of loops. This is a more brute force reset that just using the reset button
If that doesn;t work you should talk to magellan tech support. They are quite helpfull and may have some differant way to reset things. And at worse will be able to tell you if it is time to send it in.
Posted on Mar 31, 2010
Anonymous
  • 321 Answers
SOURCE: I updated software on my
The software of the unit got wiped out when you formatted the roadmate. The reason your system gets hungup was because it is not able to carr the updates you downloaded on it. Therefore, the solution was for you to have reset the device.
Now what you will have to do is to get some help from magellan, because they are the only source you can get the operating system from. Try to contact them from their help desk of:
Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT Telephone: 800 707 9971
They would provide you with the operating system for your unit.
Posted on Jan 02, 2011
My magellan roadmate 5145t-lm tells me my device needs to be restarted to increase performance
Power it down and then turn it back on... but make sure it is fully charged.
1helpful
Magellan 3030-lm needs pnd update
need pnd update for magellan roadmate 3030-lm
Dec 22, 2013 • GPS
1helpful
My magellan roadmate 3030 LM is stuck on usb conect to computer screen. will not do anything
You will need to send the unit in for repair. There is nothing you can do at home to repair this problem.
4helpful
2answers
Magellan roadmate 2120T too slow after updates
Magellan support was actually pretty good helping me with the exact same issue. The problem (at least in my case) was that the map files were fragmented. I tried using the Windows defragmenter, but that made fragmentation even worse! The Magellan support engineer recommended I download UltraDefrag instead:
http://ultradefrag.sourceforge.net/en/index.html
Here's what I had to do to completely resolve my issue:
1. Download and install UltraDefrag
2. Connect my GPS to my PC
3. Move the MAP directory from my GPS drive (J:) to my hard disk
4. In UltraDefrag, make sure Action > Skip removable media is not selected
5. Run the optimizer (Ctrl-F7 or Action > Full optimization) after selecting the GPS drive (J: on my computer)
6. Copy the MAP files back to the J: drive AFTER optimization has completed
I double-checked the fragmentation after the files were copied and got 0%. After disconnecting the GPS from the PC, the unit rebooted and doing an address search no longer takes 15 seconds. POI searchs are also much faster than before.
How to make Hardware reset of Magellan Roadmate 3055-MU?
need help hard resting minemagllan roadmate 3045-lm gps
2helpful
How to set up Magellan Roadmate to Bus mode
If your unit is equipt for this feature, then here is the operation manual link to copy and paste and put in your browser to help you.
http://www.manualbuddy.com/1598/magellan-roadmate-5045-manual
Thanks Mike
2answers
How do i update my magellan 5045 roadmate? when
Download and install Magellan's content manager software. Your GPS unit should be recognized after installation.
http://tinyurl.com/4rmxv3t
My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 • GPS
Magellan Roadmate 760 GPS Receiver Logo
Top Magellan GPS Experts
Ekse
Michael Thomas
Michael Thomas
Are you a Magellan GPS Expert? Answer questions, earn points and help others
