Microwave Ovens Logo
A
Anonymous Posted on Jun 27, 2014
How to fix door latch on panasonic inverter microwave
Model number nn-sn797s door key latch replacement
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 05, 2007
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 23, 2008
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 02, 2008
SOURCE: door does not latch close
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
David Hanks
  • 178 Answers
  • Posted on Sep 13, 2009
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
Anonymous
  • Posted on Dec 21, 2009
SOURCE: Panasonic microwave model NN-2959: can't open door.
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
1helpful
2answers
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
31helpful
2answers
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
9helpful
Panasonic Inverter door stuck
The door latch mechanism is all plastic and commonly breaks. You have to take the cover off and work on it from the inside.
Top Panasonic Microwave Ovens Experts
Paul Bade
Jerry Naidoo
Dennis Boxerman
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
