Question about Amana ARB1905C Bottom Freezer Refrigerator
What is cost to repair refrigerator defrosty - Amana ARB1905C Bottom Freezer Refrigerator
Is it worth fixing a 30 yr old Traulsen commercial reach in refrigerator/freezer? The compressor on the freezer needs replacing but the refrigerator is working fine.
Is there a compressor for the refrigerator separate from the freezer? Weigh the cost of repairs against the cost of a new unit, then decide.
Mar 16, 2016 | Traulsen Refrigerators
My roper refrigerator has a freon leak can i repair it myself?
I would say You need new fridge. Roper fridge will cost less then repair, because You will have to call refrigeration company. Job is costly, would estimate at 500$-1200$. Hope that helps!
Aug 19, 2015 | Roper Refrigerators
I have an Amana side by side American Fridge Freezer that has stopped working after 6 years, due to an internal gas leak. I am advised that this is not repairable due to the location of the leak. Whir
Refrigerant leaks can be difficult (and expensive) to repair. Leaks in exposed tubing and coils can be repaired and/or replaced, but costs can approach over half the cost of a new refrigerator (get estimates before proceeding.) Some tubing is located within the cabinet (usually foamed in place) and is therefore not accessible. A qualified technician can tell you where they believe the leak is located and confirm that all accessible refrigerant tubing and coils have been checked - ask for specifics before making a decision.
Oct 25, 2014 | Refrigerators
My product is Whirlpool Top Mountain Refrigerator. I bought it in August 2006. The freezer is working very well, however the fridge is not cool. Can anyone tell me what's wrong with my refrigerator?...
LOOK into the vents of the back of the FREEZER section...
If you can make out the vanes of the evaporator
you have a EVAPORATOR FAN FAILURE.
IF you are LOOKING at a SOLID BLOCK of FROST
you are experiencing a DEFROST CIRCUIT FAILURE.
Decide what your issue is...
Both are easy to fix...
but you will have to do a FULL DEFROST to get another week of service... if your DEFROSTis failing.
Fod spoilage... and water damage are a concern.
Do it YOURSELF... (I love refrigerators).
Read my past articles or comment me back...
FIXYA may have my login fixed soon...
Carnac the Magnificent
Apr 21, 2017 | Whirlpool 9.7 Cu. Ft. Top-Mount...
Refrigerator and freezer not cooling cleaned everthing underneath and around compresser fans all running .
Hello Earnedit03,
I understand that you are having a problem with you refrigerator not cooling at all. However, all of the mechanics are working properly. This issue will be a freon leak, this is not a DIY project as you must recover any freon (refrigerant), pull the unit down, find the leak and patch, and recharge the unit.
Is the unit worth repairing? You should call around and see what the cost of repair wil cost in your area. If the cost is above half the cost of a new unit, you are better off replacing than repairing.
Ultimately the choice is your as to what to do at this point.
Thank you for choosing FIxYa.com
Justin
Apr 03, 2011 | Refrigerators
I have a GE profile side by side refrigerator and it won't stay cold. What is the approx. cost to replace the compressor so it will get cold again?
First be sure it is actually the compressor at fault. We repair a lot of control boards for these fridges that cause the problem you describe. The cost to repair the control board is $80.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around [email protected]. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Jul 30, 2009 | LG LRSC26940ST 36" Side-by-Side...
LEAKING WATER AND MAKING A HISSING SOUND UNDERNEATH IS IT DEFROSTIING OR SOMETHING LIKE THAT
Yes. Every 12-14 hours your refrigerator goes through an automatic defrost to clear the ice from the evaporator. The hissing sound your hearing is the water dripping on to a burning hot element.
No Worries.
Jul 30, 2009 | Whirlpool Refrigerators
Sanyo SR 3620W countertop height refrigerator repair question
yes it can be repaired but it might cost you more than a new one. check with local refrigeration company on quote before they come.
May 09, 2008 | Sanyo SR-3620 Compact Refrigerator
Amana ARB1905C Bottom Freezer Refrigerator Logo
44 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
