Question about Kenmore 12-Cup Coffee Grinder and Brewer, Stainless Steel
Why is my kenmore elite grinder brewer not brewing coffee?
1 Related Answer
Anonymous
SOURCE: kenmore coffee maker wont brew model #81006
This coffee pot was recalled,I just took mine back to sears essentials last night and they replaced it with the new improved one,they just got them in.Good day,Sandi
Posted on Aug 08, 2008
Coffee beans setting too small
* Brand and model needed for specific solutions.
* Check your warranty. Call for support
*** Following is for information only.***
* Bean grinders have a dial in front or a dial near the bottom of the been funnel (or bean bin.)
* Dials usually have size settings and may even be marked for the style of coffee to brew.
* Some of the smaller grinders have a dial around the collar of the bean container that have numbers or arrows pointing to coarse or fine grind. Some use a whole bean icon then smaller sand grind icon. Others may use numbers like 1-10 etc.
* For the super automatic coffee/espresso brewers they usually have a program enabled grind setting where a mini motor will adjust the grind for you depending on your coffee choice.
* The lesser "home" or office brewers may only have one setting and needs to be calibrated each time you change beans. (This is usually an adjustment knob or screw) Coffee needs to be brewed and tasted for each change of grind setting.
* Note that often changing the grind setting will also affect the ground coffee volume. (changing the size of dregs 'puck'). This also changes the flavor profile.
* Volume changes to brew needs to be done from the programing menu of the super automatic brewer.
* Espresso brews using a standard portafilter, it's critical to adjust the grind to the portafilter basket and dose water amount.
* Brewing in the coffee auto drip needs to have larger grind and more coffee to make up for the loss of flavor from large grinds.
* Smaller grinds intensifies the flavor but brings on bitter oils if ground too fine.
* Go slow and make taste tests each step of the way. Understand that it's a multi level balance between; Heat, Water volume, Flow rate, Pre-soak, coffee roast, coffee amount, besides just the size of the coffee grind.
* Calibrating for espresso; https://www.youtube.com/watch?v=FUeCLypvlNU
* Arrows and numbers; https://www.youtube.com/watch?v=n8dJpATLrjw
* Mazzer; https://www.youtube.com/watch?v=mN_To2nv1Fs
* Delongi; https://www.youtube.com/watch?v=WTYhZoncLBk
* Delongi(super); https://www.youtube.com/watch?v=OUSXo0xaHIM
* 890TS (also Bunn); https://www.youtube.com/watch?v=QF-kiFymTQM
* Size to brew; https://www.youtube.com/watch?v=5BCDIas33y0
* Electronic dosers; https://www.youtube.com/watch?v=xMadMBgMcA4
* Hand grinder; https://www.youtube.com/watch?v=zyCHdG25JFU
* Ceado; https://www.youtube.com/watch?v=iwHdm5GtNHI
* Modern hand grinder; https://www.youtube.com/watch?v=oH2s6rQ43us
* Saeco; https://www.youtube.com/watch?v=C7nK9nsFNkQ
* Breville; https://www.youtube.com/watch?v=1lGFJoI77T4
* Gaggia; https://www.youtube.com/watch?v=5U3o9jMvI3g
* Call your vendor for additional advice.
Aloha, ukeboy57
Aug 19, 2018 | Coffee Makers & Espresso Machines
Why won't my brew station brew the whole 12 cups at on time? We have to constantly turn off then on again.
You probably need to de-scale the brewer. Use cleaning strength vinegar and run it through the brewer until vinegar comes out, then let it sit fir 4 hours or so, then flush plenty of water through to get rid of the vinegar.
Sep 24, 2014 | Hamilton Beach 47900 BrewStation 12 Cup...
My Kenmore Elite grinder and coffee brewer ground this morning, but then would not brew. Any ideas? The machine stayed on but never made another sound.
Try cleaning the chute from the grinder to the basket. Coffee oils build up and plug the chute. I clean mine every 3 - 4 days and have had no problems.
May 01, 2014 | Kenmore 12-Cup Coffee Grinder and Brewer,...
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
Only 1/2 cup or less of coffee brewing. Water is going back into the reservoir at brewing tim.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 03, 2011 | Keurig Elite B40 Coffee Maker
All lights blinking on keurig elite will not brew
heatman101
Jan 07, 2011 | Keurig Elite B40 Coffee Maker
Keurig Elite B40 Coffee Maker will not make coffee. It sounds like it wants to make coffee but coffee does not come out..
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 22, 2010 | Keurig Elite B40 Coffee Maker
Hot steam dampens coffee grinds in grinder unit
These grinds are what is left after the grind process is finished. Everyones unit does this.
Mar 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Kenmore 12-Cup Coffee Grinder and Brewer, Stainless Steel Logo
435 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
gbob59
ray gallant
Kardoc
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
