I got my iphone wet two months ago it dried out and I just took it out. I tried to turn it on it would not unless it was plugged in... and it was frozen on apple screen.. I did a hard shut down and plugged it into iTunes. now it is stuck on iTunes screen. I went today and put new battery in it.. ihad the inside cleaned and it still will not stay on with out plug. it also is in recovery mode and still stuck on iTunes page.... I tunes gives me a 21 code how do I fix the phone...
SOURCE: Iphone reset instructions don't work
u can try jailbreaking on ZIPHONE download will work as new
SOURCE: iphone is stuck on the apple logo screen
Did you try to reset the phone by pressing the power button and home key?
SOURCE: Apple iphone shows on screen ''Phone Disabled connect to itune''
did you try to use itunes to restore it to its factory settings?
SOURCE: My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: 3gs Iphone will not charge
get a toothbrush and some methylated spirits, and clean the charging jack on the iphone, as it is most probably corroded. make sure the phone is off first. and just scrub it for a good minute.
good luck\\
nick
