If you have not taken battery out of the vehicle recently and the radio code has been inserted correctly ( if a code is required with this model), you may have an audio output IC fault , this may be caused also by a faulty speaker going short and cutting off the sound ( simple but some people miss the obvious check you don't have a mute button ?) if the speakers have shorted this would most likely cause the sound chip to blow if not internally protected. so check them anyway with a digital meter to make sure before replacing the radio if needed so as not to blow the new radio. Unfortunately this question rates up there with how long is a piece of string without inspection there could be a multitude of reasons good luck with it .
If you can do it, run a jumper from the drivers door to the passenger door. Unplug both motors. try to run the passengers door off the drivers switch to rule out the motor. I don't think it is because the motor is dc. But this is the common point. Please mark this as helpful or fixya. Shuold you have anymore problems, I used to be a mobile mechanic electircian. Looking forward to hearing from you.
Bring to tranny shop or repair shop, have it scanned for trouble codes, many electrical parts and solonoids in those trannys, possible it may just be a shift solonoid bad or needs adjustment, much cheaper than replacing tranny. good luck!
