Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
How do I display the clock on the Alpine CDE-143BT
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
Anonymous
  • 100 Answers
SOURCE: how do I set the clock in Alpine CDE-9872 CD receiver?
From the Owners Manual for the CDE-9872:
FixYa won't allow images larger than 150k, so that's why this is a little blurry.
I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Posted on Nov 18, 2008
pmb1966
SOURCE: can't set the clock
Pasted from the manual:
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press
up or down arrow (CDE-9842 only) to adjust the
Rotary encoder (CDE-9846 only) or press MODE
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
press
pressing the Rotary encoder (CDE-9846 only) or press
MODE (CDE-9842 only).
Posted on Dec 03, 2008
Anonymous
SOURCE: CHANGE CLOCK ON MY ALPINE CDE-9852
push title button til time comes up, then push and hold title button again til time flashes, when it does you can turn the dial til time you want comes up,then hit mode button below dail to switch to minutes , then repeat
Posted on Apr 27, 2009
Anonymous
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
How do i get code for bluetooth
First make sure that Bluetooth is on on the CDE-143BT. Press and hold Audio/Setup (below and to the right side of the rotary encoder dial until you enter the Setup mode. Use the rotary dial to get to Bluetooth. Press the Search/Enter button (the center of the rotary dial). Then use the rotary encoder to go through the Bluetooth Settings menu. Press Search/Enter to toggle the current value. After Bluetooth is on, go to Visi M setting and make sure that it is on. Now, you need to go to the Bluetooth settings area of your cell phone when it is within range of the receiver. Tell it to pair with the receiver. Then when it asks for the code enter "0000". This code is hard encoded into the unit. See page 23 of the manual for the CDE-143BT for the code. The manual is available here: http://vault.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf . Surrounding pages show setting the other Bluetooth settings.
Note: the receiver will be acting like a Bluetooth headset. That's why you need to enter the receiver's PIN on the phone.
I hope this helps.
Oct 10, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
Alpine installation
It might wear the cd drive by putting too much weight on it.
Jul 21, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
Im buy oem harness for alpine cde-143bt but its a pink w/ black stripe i don't know what's its for becuse my honda crv 99 don't have that color cable please help me its urgent
It's hard to say without looking at the wiring diagram. You can go to the Alpine website and download your owner's manual. The wiring information will be in the manual.
Apr 05, 2014 | Car Audio & Video
Alpine cde-9842 clock set
  1. In the Clock priority mode, press and holdTITLE for at least 2 seconds while the time is displayed.The time indication will blink.
  2. Turn the Rotary encoder CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the hours while the time indication is blinking.
  3. When the hour has been adjusted, press the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
  4. Turn the Rotary encoder (CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the minutes while the time indication is blinking.
  5. The time is automatically set 5 seconds after the minute adjustment.
  6. The time can also be manually set by pressing the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
Download Alpine CDE 9842 Manual
Feb 05, 2013 | Alpine CDE-9846 CD/MP3 Car Stereo
How to set up clock standby of cd alpine model cde-102 Like I mean clock will be on when turning the key on
Turn the stereo off before you stop car. If clock is not displayed press display until clock is displayed. Then turn off car, and turn it back on it should have clock up.
Sep 08, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Can't set the clock
displayed.
press
(CDE-9842 only).
press
Oct 15, 2008 | Alpine CDE-9842 CD Player
Alpine CDE-9843
Setting Time
displayed.
only) or press
only) or press
Apr 26, 2008 | Alpine CDE-9843 CD Player
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
