Question about Electrolux Epic 6500 Vacuum
Wire hook up on electrolux epic 6500 - Electrolux Epic 6500 Vacuum
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Posted on Apr 09, 2008
Anonymous
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
Anonymous
SOURCE: cord won't rewind. How do I take apart to repair?
see jan 1, 2009
Posted on Apr 19, 2009
Anonymous
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Posted on Jan 30, 2010
Roger Potts
  • 694 Answers
SOURCE: How do I access the hepa filter on my Electrolux
Look at the back of the machine. There will be a "tab" on the top piece (aka tool caddy or air diffuser). Press on tab, lift tool caddy off machine. To remove afterfilter, simply lift off. Replace, if desired, to continue the filtering process.
Posted on Oct 24, 2010
Testimonial: "great advice. Thank you."
I need a operating manual for EPIC 6500 Model 1763
You can download the manual from the Aerus/Electrolux site.
http://www.aerushome.com/Site/Manuals
I hope this isn't too late.
Jan 15, 2016 | Electrolux Vacuums
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
Electrolux epic 6500 power nozzle works when the wand is held turned to the left and then shuts off.
The wiring is defective, more than likely the copper conductor is broken inside the insulated outer covering. This should be a very inexpensive repair at any Vacuum cleaner repair shop.
Nov 28, 2011 | Electrolux Epic 6500 Vacuum
Want wiring diagram for electrolux 6500 epic
Available only to authorized Aerus service techs and franchise owners.
Apr 23, 2011 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
How do I attache the hose on an Electrolux Epic Cannister vacuum and have it lock into place?
If you are having trouble hooking the hose to the machine, your latch is mostlikely broken. This can be replaced. You can either buy the latch at your Aerus/Electrolux shop and replace it yourself if you are mechanical or have the service manager do it for you. There shouldn't be very much of a charge for this simple process.
If you are talking about hooking the hose to the wands, there is a latch that will need to be replaced. If so, the best thing to do is have the service manager replace the latch because there are wires in the hose handle that are sometimes hard to deal with.
Joe
Nov 22, 2009 | Electrolux Epic 6500 Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
