Paper is loaded, lift tray lifts paper, sounds like some of the rollers are turning but the pickup tires are not. When manually looking and testing rollers appear to be attached and working. If you feed the paper by the pickup rollers multiple pages will be fed through scanner.
SOURCE: No paper detected
Try cleaning the rollers if that doesn't work, remove all of the rollers (feed seperator and retard) then simply reinstall them. This fixed the errors we had.
SOURCE: Canon DR-9080C paper tray lift broken
Michael,
U can buy 9080C service manual at tradebit.com
9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
SOURCE: The front paper tray that lifts the page to scan
On the right side of the scanner there is a motor just behind the small bulge in the cabinet. The motor lifts the paper tray through a bevel gear. Incase the palstic gear is damaged, it maynot lift the tray. U may need to change the gear.
Even if the tray is overloaded, the tray will not lift.
S. Mohan, Chennai, India
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
SOURCE: the paper feed on a canon 9080 is not working.
The small ribbon cable underneath of the lift tray is probably broken.
http://www.laserprinterservices.com/parts.html
https://www.partsnow.com/Forms/Login.aspx
http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html
Hope this helps helps. Please keep us updated and remember to rate this answer.
