Question about Chevrolet 1994 Chevrolet Blazer/jimmy full Size Radio
1994 chevy blazer fuel pump replace
How do i replace the fuel pump? after doing some looking online i found out its "in tank", but i cant afford to take it to the shop as i have just recently had the whole front end done on it
Posted by Steven on
ballisticpc
  • 29 Answers
Pretty straight forward. You have to drop the tank out from under the SUV there are 2 straps that hold the tank in place. Here is a youtube video of the process.
Posted on Jun 27, 2014
ElDopa
  • 295 Answers
There is a 2 part YouTube video on replacing a 1993 Blazer fuel pomp; hopefully it's similar to the 1994 model:
How do i replace the fuel pump in a 1994 Chevy S-10
wow you have to remove the gas tank its inside the tank.alot of work.there is two strapes that have to be removed that holds the tank to underside.oh this is very dangerous cause of the gas in tank.
Oct 30, 2009 | 1994 Chevrolet S-10 Blazer
Need to know how to remove the fuel pump in a 1998 Chevy Blazer
Your fuel pump is located inside your fuel tank. You need to drain and remove the fuel tank to replace it.
Jun 11, 2009 | 1998 Chevrolet Blazer
Where is the fuel pump located on a 1994 chevy blazer
it is located in the fuel sending unit at the top of the tank. You have to remove the tank to get to it.
Jun 10, 2009 | 1997 Chevrolet Blazer
Chevy Blazer won't start; fuel pump needs replacing
Before spending several hundres on a fuel pump, I recommend doing a fuel pressure test. You can get a test gauge pretty cheap at a parts store. If the pump is junk, you raise the truck, lower the fuel tank, unplug the electronics from the pump at the top of the tank, then with a hammer and flat head scrwedrive, gently tap the lock ring in a counter clockwise direction until it pops off. Pull the pump assembly out and install the new one. Reverse directions to install.
Jun 02, 2009 | 2001 Chevrolet Blazer
Fuel Pump
You will have to drop your fuel tank. This can be difficult if you don’t have a floor jack and some help. Removing the filler neck and fuel lines are usually the hardest. A couple of thing to remember are to use open end wrenches to loosen fuel line fittings and not to let the tank down to far before disconnecting the wires. Expect to spend 3 to 4 hours if you haven’t done this before.
Jul 26, 2008 | 1994 Chevrolet S-10 Blazer
Chevrolet 1994 Chevrolet Blazer/jimmy full Size Radio Logo
189 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
