Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
I cant get my canon powershot sd750 to flash - Canon PowerShot SD750 / IXUS 75 Digital Camera
5 Related Answers
darntoothysa
Thomas D.
  • 489 Answers
SOURCE: I donĀ“t have drivers of my Canon PowerShot SD750
Hi
If you have Windows XP, you don't need any drivers it's already in the Windows operating system for you; just connect the camera to the computer via USB and it should work just fine. If you have a different operating system you can download them directly from Canons website.
I don't post links sorry, but go to usa.canon com, then click on the cameras and search for your SD750, then click on 'drivers and downloads', you will find older Windows drivers as well as Mac.
And as for "devilived" yes, you need a driver to connect a camera to a computer to download pictures. A driver is a piece of software that tells Windows how to talk to a piece of hardware you are connecting to the computer. XP has more drivers already installed in the OS than previous versions of Windows... and Vista has more driver problems than most other previous versions of Windows.
Good luck with your camera Flota61.
Thomas
Posted on Oct 13, 2008
Anonymous
  • 246 Answers
SOURCE: Will not take a picture with the flash on
It sounds like your flash unit is broken. If you can DIY, try to open the camera, check the fuse and the inductor on the flash unit. Here is a tip for your reference:
How to fix a Canon SD750 with intermittent flash problem
Posted on May 30, 2009
superdave1
  • 156 Answers
SOURCE: my sd750 will not start up
Does the lens cover move when you do this? If it doesn't, it sounds like that might be the problem.
Posted on Jul 06, 2009
Ty Price
  • 11967 Answers
SOURCE: canon sd750 powershot lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 26, 2010
Anonymous
SOURCE: how do i turn on the date stamp on my Canon Powershot SD750
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Posted on Feb 12, 2010
I have a Canon PowerShot SD750. I dropped it and the flash not working. can i get a solution for this
Sure: Solution #1. Stop dropping it.;) Solution #2. Send it in for service. Be prepared...it will be expensive.
Oct 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do you turn the flash off?
Press the flash button (right on the multiselector, marked with a lightning bolt) repeatedly to cycle through the various flash modes. To turn off the flash, select the lightning bolt in a circle with a slash through it. Don't forget to turn it back on later if you want it to flash.
Jul 22, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I turn my flash off?
Press cursor-right (marked with a lightning bolt) to bring up the flash menu, then select the lightning-bolt-in-a-circle-with-a-slash-through-it icon.
Dec 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My daughter vomited on my Canon PowerShot SD750 (Black)???
Get an estimate of the repair cost and then decide whether to get a new one or not.
Aug 12, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error restart camera SD750
somebody saying under warranty
http://www.digitalcamera-hq.com/digital-cameras/canon-powershot-a570is_question.html?qid=12688
May 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
May 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Jan 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Unfocused
Take it back to whoever TRIED to fix it.
Dec 26, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
