Question about Fuji FinePix S304 Digital Camera
Finepix S7000 battery chamber cover
Serie 41M15452 battery chamber cover is broken
5 Suggested Answers
Anonymous
  • 425 Answers
SOURCE: The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Posted on Aug 29, 2005
Anonymous
  • 667 Answers
SOURCE: Replace Battery Cover
Okay,
Separating the front and rear covers of the camera is not that difficult. You'll need a good small cross point screwdriver. I do not have a 2600 in front of me, but the 2650 is similar. Remove all the screws around the sides of the camera. The top sections are snapped together. work along the back edge to undo the snap tabs. I do not remember if there is a ribbon cable attached so go easy when you remove the back half.
My chat is not working yet, so if you want to go this far, let me know
Posted on Jan 24, 2008
Anonymous
SOURCE: Battery lid or cover
I have a s5500 with the battery lid clips broken.. fuji says ,, nope no warranty on that part ,, what a joke,,$120 dollars labour plus parts and freight for repair... anyway ,, went to jaycar (electrical supplies etc) and found a small metal clip/ fastener that I used on an existing exterior screw below where the strap is located. i then placed another screw in the lid that allows the remainding hole in the fastener to slip over, works like a charm. took me around 3 minutes to do and does not affect the grip on the camera and still alllows it to be easily opened and closed. I am most pleased i now have my camera back.
Posted on May 01, 2009
Anonymous
  • 109 Answers
SOURCE: finepix s7000 new 4gb card not initialized fujifilm cf
The S700 as it came from the factory CANNOT use a 4 gig card. You must go to the Fuji USA website and download the firmware update. You will need to have the program that came with the camera installed, and the cable that also came with the camera. Make sure that you have fresh batteries in the camera. Instructions are on the Fuji website along with the download for the firmware. You are actually going to "flash" the firmware in the camera just as if you were doing a BIOS flash in your computer. Personally, I only use smaller cards and remove the pics soon after I take them. A 2 gig card will hold about 150 full rez pics. Get them out of the camera....don't save them forever on the card!
Posted on Aug 01, 2009
Anonymous
SOURCE: Where can I get a replacement plastic battery door
I didn't see where anyone had replied to this. II ordered a replacemtn door this morning frmo Fuji. Around $13 including shipping.
Just told them what I was looking for.
1-800-659-3854 and enter extension 3451
Posted on Sep 10, 2009
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How do i change the memory back up battery?
Hello
You can replace the battery without loosing its memory. Follow these instructions. Battery must be changed as fast as you can. So read well and they do the work.
o Bose radio uses a standard nine-volt battery that serves as a backup for the memory and alarm when it's unplugged or when the power is off. It will power these functions for up to three days. Using the radio without the battery won't damage it, but the memory won't be backed up. The battery does not provide enough power for normal operation, including the lighted display.
To install a battery, turn the radio over. Push on the arrow on the battery chamber cover and move it aside. Match the terminals on the battery with their opposites inside the chamber, and push the battery securely into place. Close the cover and return the radio to an upright position.
Connect the power cord to the jack on the back of the radio. The flat side of the connector must line up with the flat side of the jack. Since the power cord contains the FM antenna, uncoil the cord for the best reception. Plug the power cord into a standard electrical outlet.
An FM cable connector is on the back of the radio. Contact your cable company for help in setting up your connection. When you set it up, be sure to use a splitter that separates the FM signal from the TV signal so that the TV signal won't be transmitted to your radio.
If your remote is slotted on the back, press the tip of a pen into the opening and push the battery chamber cover to the side. If there's no slot, push the tab to one side with your finger and open the chamber cover. Use only a lithium battery size CR 2032 or DL 2032. Place the battery into the chamber with the plus sign face-up. Push the chamber cover closed and it will lock.
Mar 18, 2011 | Bose Wave Radio
The battery chamber has broken off and been like that for at least 6 months. I have only owned the camera since June 2010. Will my warranty of one year still cover me? More importantly: Where do I send...
The warranty will cover the battery chamber, I would take it back to the store and let them deal with it, since they sold you the product in the first place and let them know you are not happy with the purchase and that you expect them to take care of the problem. I find you get more prompt service than if they try and say it is the manufactures problem, don't let them sway you. When you call the manager out, the last thing they want is bad publicity especially when you have prospective buyers going shopping, I think you will do far better this way under the circumstances.
Mar 11, 2011 | Vivitar ViviCam 8018 Digital Camera
Broken Battery Chamber Cover. Need replacement part (in Canada).
What is the band and model number of your digital camera?
Mar 01, 2011 | Cameras
How do I replace the battery chamber cover on a Nikon Coolpix L14?
unlock the broken cover pull the cover and push a new one.
Apr 10, 2010 | Nikon Coolpix L14 Digital Camera
The latch on the battery door of my Nikon Coolpix
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
Dec 29, 2009 | Nikon Coolpix L11 Digital Camera
Removing battery chamber cover, nikon d40x
tilt the battery chamber cover by some 45 degrees, and then just snap gently to pull out
Jan 31, 2009 | Nikon D40x Digital Camera
Nothing works
Remove batteries and clean contacts both inside the battery chamber and on the chamber lid/cover.( use something slightly abrasive ). If this doesnt help replace fire fuse situated on the main pc board ( underneeth rear cover ).
Aug 27, 2007 | Kodak EasyShare C643 Digital Camera
Fuji FinePix S304 Digital Camera Logo
59 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
