Sewing Machines Logo
A
Anonymous Posted on Jul 20, 2017
My machine will run a perfect zig zag stitch, then skip a stitch, then do more perfect zig zags, then skip several stitches, giving me a straight line of stitches, then do a few more perfect zig zags, etc. I have changed thread, rethreaded, cleaned the bobbin area, and changed the needle. The top tension is set on automatic. The fabric is a medium weight cotton. What might be causing this?
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Jul 23, 2017
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2618789
Points
59176
Unless the machine timing is off, the most common resolutions for skipped stitches:
Install a brand new needle.
Be sure the needle, thread, and fabric are compatible, ie do not use a ball point needle on woven fabric.
Rethread the machine and verify the thread path is correct.
AVOID old or bargain bin thread.
Basic Maintenance Tension Skipped Stitches
K McMurdo
Level 2:
Sergeant:
  • Expert 293 Answers
K McMurdo
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
87363
Points
755
Sounds like the timing is off and will need a service call to get it reset. your local fabric store should know who you can call.
5 Related Answers
Anonymous
  • 46 Answers
  • Posted on Sep 02, 2008
SOURCE: zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Anonymous
  • 208 Answers
  • Posted on Jul 11, 2009
SOURCE: The bobbin thread is bunching on the under side of
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
bargainbox
Hassy
  • 1388 Answers
  • Posted on Aug 30, 2009
SOURCE: zig zag stitch is skipping sporatically
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Anonymous
  • 5 Answers
  • Posted on Feb 13, 2010
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Apr 11, 2011
SOURCE: The machine is not stitching
If the bobbin thread is coming up to the top, then the thread is not under tension correctly. I think that this is a top loading bobbin so the bobbin will go into the bobbin holder, then you pull the thread back and press it into a tension device - should hear it click into tension. Now pull the thread back towards you and it should not come out of the tension. The bobbin should turn anticlockwise as the thread is pulled from it.
These bobbin holders usually will have a small adjustment dial on them and it should have the standard setting marked in red. It is very unusual that you would need to change this but check that it hasn't been messed with perhaps. If you have the machine manual check where they say the dial should be set. More likely that the thread is just not into tension fully or at all.
The manual may give you other troubleshooting tips too.
A good resouce is www.sewing.about.com for general machine tips, cleaning and threading issues.
Hope this helps.
How do I get it to zig zag
There is a dial or a lever that you turn it to. It usually has a straight line picture for straight stitch and a zig zag photo for the zig zag stitch.
Why won't my zig-zag zig zag?
Check your stitch width setting if its too low it will just straight stitch.
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
1helpful
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
3helpful
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
1helpful
2answers
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
1helpful
Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions [email protected]
2answers
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
