Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
My refrigerator is warm
My freezer part works fine it cool of but my refrigerator is warm don't understand!
Posted by boricualocon on
  • 3 more comments
  • MKO Jun 12, 2008
    I have a GE GSS22JEMDBB sid by side refrigerator. The freezer side works except alot of moisture is gathering on the roof and sides of the freezer walls. The refrigerator side stays about 60 degrees. I removed the
    back panel of the freezer side and melted all the ice packed around the coils. I replaced the panel and it seemed to be working for a couple of days. Now the freezer side and refrigerator sides are doing the same thing. What do I do to keep the coils from freezing up in a big chunk of solid ice?
  • Anonymous Jul 19, 2008
    the freezer side freezes good but the refregator is warm
  • yellup123 Jul 28, 2008
    My refrigerator is only 8 years old. It is a side-by-side. The freezer part is just fine, but the refrigerator part is now warm and will not get cool. What could be the problem???
  • suesbaskets Jul 29, 2008
    The freezer is good but the refrigerator is not cold. We have had a repair man 4 times to fix this problem. It is only 3 years old. We have to take everything out of the freezer and refrigerator and let ice melt that gets built up between the freezer and refrigerator. The freezer blows cold air into the refrigerator and thats how the refrigerator part gets cold. I don't understand how it keeps getting ice build ups.
  • mikemcglynn Jan 08, 2009
    my upright Bosch fridge freezers freezer is working fine but the fridge is warm I seem to have fluid leeking at the back it is only 2 years old what could be the problem
eagle338
  • 4,889 Answers
This problem is due to plugged defrost drain line..Click on the link below(i have already solved this problem).Note that this is generic problem with refrigiratorsand the troubleshooting procedure is same for any model or brand..
http://www.fixya.com/support/t226483-kenmore_50222000_help_me_please
Posted on Nov 06, 2007
Erik Maynard
    Problem Solver:
  • 7 Answers
I took the evaporator panel off and it was all frosted up. I am assuming the panel acts as its ductwork and with it being totally frosted throughout the spine fin evaporator no air can go through. So, now that we lost all our food, I am hoping it gets cold fast again. Morning will tell. Polk City, Florida
Posted on Apr 15, 2013
  • Erik Maynard
    Erik Maynard Apr 15, 2013
    To add to that above, I did take a hair drier and it took about 25 minutes to thaw it all out.
Anonymous
  • 4 Answers
Another option is that the condenser fan, the fan right above the cooling coils is not working. This fan circulates the cold air and if it's not working it can't move the cold air over to the refrigerator side. Open the door and press the switch that tells the computer the door is closed (so the light goes out), if the fan doesn't come on shortly, or only sputters that could be the problem. As you take it apart, be sure to take some digital pics of the process so you can remember how it goes back together!
Posted on Feb 13, 2009
5 Related Answers
Anonymous
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Regrigerator isn't cooling - freezer is fine....
Make sure there is not a ice build up in the back wall of the freezer.
If so, you have a defrost issue.
Make sure the freezer fan is blowing.
If so, you have a thermistor issue.
Posted on Feb 22, 2009
Anonymous
  • 7 Answers
SOURCE: freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Posted on Apr 19, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Anonymous
  • 58 Answers
SOURCE: FREEZER IS WORKING FINE BUT REFRIGERATOR IS NOT
Check to see if there is frost or ice build up on the back panel in your freezer. If there is you have a defrost problem and the air is not circulating to your refrigerator.
Posted on Sep 17, 2010
Testimonial: "THERE IS SOME FROST BUT NOT ENOUGH TO CALL IT A BUILD UP I WILL CONTINUE TO OBSERVE FOR THE NEXT 24 HOURS, THANKS FOR A GREAT TIP."
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
I have a fridge that was made in 1995 that the fridge stays warm freezer works fine I also can not fine a model @ that I can read
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
I have a Frigidaire freezer chest. model number: mfc13m4fw3. It will click on for ten seconds and click off. I don't understand whats wrong. It wont stay on. Thank you
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2011 | Frigidaire Freezers
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Amana freezer on bottom working fine, but refrigerator not
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
3,729 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
