Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
Is the Ryobi 18 Volt model P101 same as P100?
5 Related Answers
rowdy45176
David Ford
  • 2176 Answers
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Posted on Dec 31, 2008
transit360
  • 74 Answers
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Posted on Feb 10, 2009
Anonymous
  • 104 Answers
SOURCE: my 18volt Ryobi battery needs the inside batteries
Yes you can replace the inside batteries yourself , just take the old ones out and go to Battery world or a similar shop and get replacements then all you have to do is repack them yourself and put them back into the battery case .
Posted on Jun 12, 2009
Joe Bannon
  • 1514 Answers
SOURCE: will 14.4 volt charger charge
I'm afraid not. It will damage the battery if you try. You'll need to get the correct charger.
Posted on Jan 12, 2011
John McPherson
  • 1212 Answers
SOURCE: ryobi 18 volt battery charger
If replacing the charger is not an option, open it up and check the fuse. Another item to check is the current limiting resistor, color coded red-red-black.
Posted on Feb 18, 2012
Why doesn't the spindle lock button depress?
no it will not stay depressed
simple reason
if it stayed depressed then most people would forget that fact and power on thereby destroying the unit
Jun 27, 2015 | Ryobi P501 18 Volt 5 1/2" Circular Saw...
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Aug 08, 2012 | Coleman Cable Coleman 18 Volt Combo Drill...
18 volt batteries
Yes you can, as long as the batteries are the same style and fit the older Ryobi tools. The Ah rating is a capacity rating. The higher the Ah, the longer the battery will last so the 1.7Ah will just last a bit longer than the 1.5Ah batteries, but yes you can use them on older 18v Ryobi tools. I do it all the time.
Mar 01, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
87 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
