Question about Nokia N95 Cellular Phone
Files protected I have put a few midi and sis files which are freeware but when I try to send them via bluetooth I get the message 'Unable to send protected objects'
Posted by Fuk2mol on
  • 1 more comment
  • Fuk2mol Nov 07, 2007
    I tried that solution but still get the same problem - when the data files are on the phone and i want to send them to another phone via bluetooth or infrared the message still appears 'unable to send protected objects' when i know that they're not protected. many thanx
  • DreamBox Feb 27, 2008
    i want to send some mid files via mms but i can't! how i can solve this problem?? all my mid files are freeware but still rceiving this Error :(
  • Erhard Oct 16, 2008
    Even installed Ybrowser and that gives me the option to send via bluetooth, but not MMS.
Mohd. Ismail Ansari
  • 178 Answers
You may simply rename the files to something else and then try to send them via bluetooth.
Example:
rename "blue.sis" to something like "blue.sis_"
or rename "blue.midi" to "blue.mi"
any name can be tried.
please Rate!
Posted on Oct 30, 2008
Anonymous
Download the program 'X-plore' from
http://www.lonelycatgames.com/?app=xplore
(you scroll down to the bottom and click "download software")
then install the 'S60_3rd edition...." file to your mobile. i tried it and i can send MIDI files on my N95 im sooooooo happy hehehe!! ^^!!! by the way, i use the 'free' version that doesn't have all the features in it, but its enough to be able to send things : )
goodlucK!
Posted on Jul 15, 2008
Anonymous
The phone's browser is set up to stop people sending applications and music to one another in case people are sending music to each other instead of using the music shop that nokia are about to open ;) I recommend you download a piece of freeware called "Y Browser" and all of the plugins that go with it as this will let you bluetooth anything and gives access all areas to the file system of your phone. It will also let you save things to your memory card that people bluetooth to you and save it out of your messages and other useful things. I have tested this ok and have bluetoothed this app and associated plugins to other n95 users since.
Posted on Nov 09, 2007
Anonymous
That sucks
Anonymous
  • 45 Answers
Dear
save ur datas through cable to PC and then,
reset ur phone by typing *#7370# .phone will ask ur security code .type 12345 or if u have other type that.after reseting download from pc and try it now
Posted on Nov 07, 2007
My Samsung galaxy portal GT-15700 phone will not allow files to be transfered to mobile, or to even transfer files to my computer or to send this files via bluetooth.It always says 'not...
I have the same problem with the same phone.
I bought a Zeemote (bluetooth controller) which needs to have a .sis file installed on the phone, but the phone does not recognize the file type.
Please help.
As for mefonna's problem, I usually connect my phone to my laptop, go into 'My Computer' to access the phone and just transfer files (drag and drop) across directly to your phone from there.
There is also an app you could download called 'Bluetooth File Transfer' (which is free) to transfer files via bluetooth.
Jan 12, 2011 | Samsung Propel Pro SGH-i627 Cell Phone
Tip
Sending SIS files via bluetooth from NOKIA to NOKIA or other phone
Some nokia phones does not permit to send contents like *.sis files or .sisx files. If you really need to send those files to other phone. Just <b>rename</b> the file with <b>file manager software</b> in your phone. Rename *.sis files to *.jpg, or *.mp3, and send it to other phone via bluetooth. then rename back as *.sis or *.sisx from receiver handset and use the file.
on Jan 15, 2011 | Cell Phones
Tip
Send softwares via. bluetooth or ir
u can send .sis files or .jar files via bluetooth by renaming it as .si or .ja like that.....
on Apr 25, 2008 | Nokia 6600
I can send files via my blackberry pearl 8110 bluetooth, but iam
1. Go to Media.
2. Hit the menu key (left of trackball) and select Explore.
3. Browse to the folder you want to store the file in.
5. Hit Menu key again and select "receive using bluetooth."
6. Send from the other phone.
You'll have to do this for each file individually.
Also make sure that you have paired with the device you are trying to receive from. In my limited experience i noticed that NOTHING transfers unless you are paired.
There is one more setting I would check, go to OPTIONS/SECURITY/GENERAL SETTINGS/make user the the
option for CONTENT PROTECTION is disabled.
Jul 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Not able to send anythin via bluetooth....!!!
I don't know whether its exactly the solution or not, but I had a similar problem transferring some mp3 files to any cell via bluetooth from my nokia 7210, I tried all combinations of bluetooth settings, but the same message kept appearing-"Sending failed", finally what I did was "Changing the name of the mp3 files" as all those I wanted to send had a bigger name, I cut the name short and there it worked. So, may be in any such case it's advisable to just try this out, it might just work.
Jul 17, 2009 | Sony Ericsson K790i Cellular Phone
I'm not able to send any file bigger than phone memory with ngage
u can send files via bluetooth using card memory as messaging memory ,i know this option is not in ngage, u can turn the messaging memory using the software "msvDrive"just install the msvdirve.sis on ur ngage and the memory will change when u execute it.
May 19, 2009 | Nokia N-Gage QD Console
Problem with renaming a file.
u can send files it from a pc with the same extension..
Dec 27, 2007 | Nokia 6070 Cellular Phone
Bluetooth
restore ur handset.and try via diff handset for confirmation purposes.
Oct 23, 2007 | Nokia N95 Cellular Phone
Support for sis file application
This is a Series 40 phone , it dosent support sis files.only series 60 and above will support sis files. please rate this comment.
Sep 02, 2007 | Nokia 6288 Cellular Phone
Nokia N95 Cellular Phone Logo
459 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
