Every time i make copy its dark with streaks run over
SOURCE: Vertical streak near left edge of printouts....only affects black portion of print image
Get a new printer. I have replaced the photoconductors - both black and color - every 5000 pages or so. I am replacing the printer.
SOURCE: streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
SOURCE: black streaks
Did you re-fill the black toner cartridge with genuine Ricoh toner or from somewhere else? It might be the wrong granularity.
SOURCE: Color Streaks down length of page
This is a laser printer, neither a copier nor a multifunction unit, therefore it has no glass. At least, I cannot find any glass in it.
I finally had an authorized Ricoh repair center examine it and found streaks on the black unit that pulls out of the right side (I forget the part's name, <$90). We replaced it and things are better but streaks of color remain. They suggested replacing the color one (about $400) but the cost is prohibitive right now, so I'll live with those streaks.
On a related note, I remain unimpressed with this printer's quality and inconsistency. For example, greys often print in pink; nothing has ever resolved this. I refuse to put any more money into it. When I can afford to do so, it will be replaced, probably by a Xerox Phaser.
SOURCE: how to clean lens on our ricoh CL3500N Laser printer
Toner spills can be cleaned with a cotton pad and alcohol. If excess toner appears do the following:
You should replace the PCU if prints show any of the following symptoms.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
