Question about Mitsubishi WD-73833 73" HDTV
What is a dmd on a mitsubishi 73" tv - Mitsubishi WD-73833 73" HDTV
Posted by Deborah Young on
mikedee4
    Problem Solver:
  • 5 Answers
Howdy Mike-d. here,
I do not know what a DMD is on a Mitsubishi 73'' TV.
I did do a little web searching and here is a couple of things I came across.
From this website: http://www.tvserviceparts.com/Mitsubishi_DMDChips.html WD73833 ALL 4719-001997 DMD Chip, DLP, 1920X1080/XHD5, 0.65"/ DC4, TYPE X NON
I have no ties to these websites.
"I researched this and it was a DMD chip that needed to be replaced."
from this website: http://www.consumeraffairs.com/home_electronics/mitsubishi.html
Hope that helps.
Mike-d. out
[email protected]
Mitsubishi TVs and Electronics Mitsubishi TV DMD DLP Chip
Posted on Jul 01, 2014
My Mitsubishi WD-73737 73 in TV has white dots taking over the screen
Bad DMD chip
call Mitsubishi, they will send one to a servicer at no cost, you will only pay for labor
Sep 19, 2014 | Mitsubishi Televison & Video
How to clean mirror and optics mitsubishi 73 dlp
You have to remove the lower panel on the back of your tv, then remove the light engine. Unhook the wires attached to the DMD board. Remove the DMD board. Remove the heat cink from the DMD board. remove the optical lens but don't touch the lens. There is a video on shopjimmy.com that shows the entire procedure. Takes 2 hours. The optical lens can be cleaned with an eyeglass cloth, same for the DLP chip lens. no wet solutions on lenses. Remove dust from other internal parts with compressed air in a can. Your picture will be clean and clear. Wear latex gloves and make sure you are grounded to prevent static electricity.
Feb 23, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
The status light on a wd-73838 and a wd-65838 keeps flashing
the problem on this tv is the dm pcb , not the dmd , or may i say main signal board , also u can open the tv and chack for bad capacitors but if there is not bad capacitor you would need to replace the main pcb
Feb 12, 2012 | Mitsubishi WD-73838 73" HDTV-Ready DLP TV
I have a 73" mitsubishi diamond edition tv and
this is when dmd (digital mirror device) ic begins to fail. these dots will become more numerous until they fill the screen. replacement of dmd board will solve
Sep 27, 2011 | Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
We are having white dots appearing on our Mitsubishi DLP 65 inch television, approx. 3 years old. It looks like a constellation is appearing. New dot every day.
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Jun 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Mar 05, 2010 | Mitsubishi WD-73734 73" Television
Mitsubishi WD-73833 73" HDTV Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
