Samsung HLN467W 46" Rear Projection HDTV Logo
A
Anonymous Posted on Jun 27, 2014
Is there a reset button after I replace my lamp on my samsung dlp hln467wx?
gemagm
Level 3:
Master:
  • Samsung Master 689 Answers
  • Posted on Jan 31, 2015
gemagm
Samsung Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119692
Points
1147
The following website will guide you thru resetting lamp timer. while in this menu DO NOT MAKE ANY OTHER ADJUSTS AS YOU CAN GET THE TV IN A POSITION THAT IT WILL NOT OPERATE.
5 Related Answers
A
Anonymous
  • Posted on Dec 11, 2007
SOURCE: Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Thanks for your solution. This is a problem with color wheel. I could not fix it by myself, so my friend will try to fix it next week.
Anonymous
  • 51 Answers
  • Posted on Dec 27, 2008
SOURCE: 3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
Anonymous
  • 505 Answers
  • Posted on Jan 08, 2009
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Anonymous
  • 114 Answers
  • Posted on Mar 25, 2010
SOURCE: Shadow appeared on my DLP TV after replacing the lamp
I found a series of reference guides that really helped me with my Samsung DLP TV.
http://www.fixyourdlp.com/forum/viewtopic.php?f=4&t=1315
http://www.fixyourdlp.com/forum/viewtopic.php?f=4&t=1321
http://www.fixyourdlp.com/forum/viewtopic.php?f=21&t=1289
Anonymous
  • Posted on May 17, 2012
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
I had projection bulb go out (explode) in my toshiba DLP tv. Pulled out bulb and housing assm. and could see it. Ordered a replacement bulb online, an aftermarket one and replaced it. Lamp led would keep flashing, blue led on, sound ok but still no picture. You could hear tv going through its self reset and after eight attempts red lcd came on. Info online suggested lamp door not seated properly, rechecked and door fine. I pulled bulb housing and made sure it was completely seated and it was in as far as it goes. Checked bulb housing contacts and they looked ok. The aftermarket housing assm. did not "feel" the same as the original when installing into tv even though they looked identical. Swapped new bulb into old housing, cut old harness and plug off of bad bulb and crimped on new ends at bulb end reusing original plug and harness (observe new bulb harness to keep wire locations correct) reassemble and install housing. Worked as soon as tv turned on. Watch out for non oem parts, they may look identical but something may still not be quite right.
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
7answers
Lamp timer near 10K
just go through the manual it will guide you to solve your problem..........
Rear projection dlp
If all connections have been checked and the lamp is confirmed working, then I'd agree with the tech. Sorry for the bad news, especially since I know it's not a cheap repair :(
I have a Samsung DLP HLS 5086 W that is shutting down after a couple of minutes. The color wheel and lamp were both replaced a little over a year ago. The lamp is a Phillips, and the color wheel is OEM. I...
Hope this helps:
Resetting the counter Once you have installed your OEM replacement lamp, resetting the counter is a very simple procedure:
• Begin with the TV powered off.
• Point your remote towards your TV.
• Press:
• Menu + 1 + 8 + 2 + Power.
• Your TV set should now say "Loading Factory".
• Browse down to "Option" then press Enter (or the right cursor button).
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
Resetting Your Samsung DLP Lamp Hour Meter Counter or Lamp Timer DLP Lamp...
2helpful
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
1helpful
Lamp Light on the front is flashing green.
www.pdfee.com/.../Toshiba%20rear%20projection%20training%20manual - United States
www.pdfee.com/search/panasonic+rear+projection+tv - United States
www.scribd.com/.../Hitachi-Training-Manual-Projection-Television-DLP-1 -
Those links should help you understand what's going on. You need to get a service manual, like those supplied, but for your exact make and model.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010300&prd_mdl_cd=&prd_mdl_name=HLN467W
3answers
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
2answers
13helpful
4answers
I have a Samsung HLN467WX DLP 46" TV. It had the Light Engine assy replaced in March 05 through warranty, but now it has stopped working. When you turn it on, the picture is fine for about 2-3 minutes...
I suggest going to the following link. they will have the service manual for your model available by email after purchase and they offer free tech support to help you with the diagnosis and repair of your DLP heres the link in case you want it.
http://servicemanuals.vstore.ca/
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
