Your question doesn't make sense as it is written, but if the real question is what size generator do you need to start the air conditioner I might offer the following....
Look on the air conditioner product label and you will find information concerning the supply voltage and current. This is a 2 ton unit and it probably requires 220VAC power. Also on the label will be a value for the maximum OPD (over current protection device). This indicates the maximum fuse or circuit breaker that can be installed in the power feeder line for the air conditioner. You will need a generator that is capable of supplying this amount of current during the start up of the air conditioner. The value is usually about 2-1/2 times the normal operating current that the generator will need to supply continuously. This is because the air conditioner is full of motors that draw a lot of current when starting up. If the generator can't supply sufficient start up current, the motors will not start and the AC will not operate. As a result, the generator size is usually relatively large in comparison to the actual size required to keep the AC running after start up. This is also why AC units are not typically powered from generator power. Good Luck!
