Question about Danby DKC645BLS Compact Beverage Cooler
Replacing the touchpad
How do you replace the touchpad?
Posted by Ori Handwerk on
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Lo scroll touchpad non funziona samsung p530
google translated
touchpad scroll does not work samsung
Feb 07, 2013 | Samsung P530 Notebook
Runaway touchpad on HP laptop.
I have the same problem. An external mouse does not behave erratically. If the touchpad is wearing out, will a replacement touchpad solve the problem, or does the circuit board need replacing?
Mar 31, 2012 | HP Computers & Internet
My mouse pad stopped working on my Compaq Presario 2200.
if this is the touchpad, try to reinstall the touchpad driver. You can uninstall it through the device manager while using an external mouse, then download the latest driver from your system manufacturer's web site. After that, make sure the touchpad is enabled and if this does not work, you may need a replacement touchpad, though you may also try system restore or OS reinstall.
Aug 31, 2010 | Computers & Internet
Replace worn touchpad buttons HP compaq 6820s
It's better and easier to just replace the whole touch pad assembly and top cover. It's all one piece...much easier and cost is the same.
This is the part number:
457616-001
Nov 23, 2009 | HP Compaq 6820s Business Notebook
Keypad froze on lg microwave
Does it have a membrane type touchpad?
Just went through that. The touchpad was bad. Some numbers and functions would work - others wouldn't. Ended up replacing the touchpad. It cost about $31.00, including shipping.
Most touchpads attach with two side adhesive. The complication in the replacement usually involves the ribbon cable that connects the touchpad to the microwave control module. I had to disassemble the door to detach and reattach this cable.
Oct 16, 2009 | LG 30" Over the Range Microwave Hood with...
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Touchpad replacement
You can replace the touchpad.
However, the Dell touchpad is part of the "Palm Rest" assembly (See item #4 on this page of the service manual). The "Palm Rest" is a large part which consists of the entire top of the computer surrounding the keyboard).
This is difficult to determine online, because we need to search for "Palm Rest" not "touchpad".
Jun 01, 2008 | Dell Inspiron E1505 Notebook
Danby DKC645BLS Compact Beverage Cooler Logo
Top Danby Refrigerators Experts
Glenn Smart
Glenn Smart
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
