Question about Hotpoint Aquarius WF220 Front Load Washer
How to set computer reset procedure - Hotpoint Aquarius WF220 Front Load Washer
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
Tip
My Opal does not start. How do I reset my Opal?
Hi.
The procedure below is the full troubleshooting when the RCA Opal is completely irresponsive and does not complete initialization.
Try first holding down the Power/Menu button for over ten seconds. This is called soft reset, and will reset the player to default factory settings. This reset will not delete personal files.
Depending on the model you may also have a reset button. In that case hold down the pinhole switch using a paper clip for more than ten seconds to perform an hard reset. It will take one or two minutest to restart the Opal after this reset, as files must be reinstalled.This reset will delete files and personal settings.
If that does not work, it means that system files are damaged. In that case you will need to reinstall the Opal firmware. Firmware for some model may be available online, but better calling or contacting RCA and asking them to provide you with an updated firmware for your unit. If the wrong firmware is installed the Opal may result damaged.
RCA can be contacted at the number listed on Opal documentation. Number in US should be: 1-800-878-5779 (RCA Audio Products Repair Centers and Warranty Info).
You can also get the firmware asking a question online. Use the following link: Create an Incident or ask a question.
See also: Information on RCA Opal M4001 MP3 Player.
To update firmware follow procedure below:
Download the firmware upgrade file.
Hold down the play/pause button for about twenty seconds .
Hold down menu button for more than 10 seconds
Keep holding play/pause button and attach Opal USB cable to computer at the same time.
The firmware upgrade will start
If you get an error saying that Windows cannot write to the Opal drive, that means that the Opal internal drive must be re-formatted. In that case go to Computer, click the right button of mouse on the Opal, and choose Format from the dropdown menu.
After formatting, restart both units, and restart firmware upgrade procedure.
Note: The procedure above must be used when the Opal is not starting at all. When instead the opal is starting, but it is not recognised by the computer, procedure will be different. In that case test the player on a different computer. Test different USB cable.Restart computer and Opal. Reset computer by disconnecting power cord, and eventually removing battery for five minutes. Try using System Restore to restore the computer to a date before having the problem. Reinstall Windows Media Player. Check System and USB hardware settings and driver on computer..
on Mar 31, 2010 | RCA OPAL M4001 MP3 Player
The wifi turns to off and will not switch back to on. The only way to get back to on is to go back to original settings and go through the whole set up procedure again
Only that problem I saw on the table, I need it reset and setting again, I need more details, please
like computer,laptop,etc
Jun 06, 2017 | Internet Computers & Internet
Can it be reset to original as new out of the box.I made a mistake in the set up and although it works it is not as it should be.I need to add I am in my early 70s and I am not to hot on tech.terms.
Hello Douglas, I am not far off my sixties so this will be a very
general description of the procedure that will require you to do some checking yourself.
There will be a number of menus available to you when you press the menu buttons on the remote control.
Look for the general and settings menus rather than those relating to tuning/audio/video etc..
You should carefully search through the settings and general menus until you find something like 'factory reset' or 'reset to factory default'
You simply need to highlight the option and then press the button to reset.....you willl [psson;y be asked to ok the procedure. It is very straightforward and should not take very long to carry out
Good Luck
Jun 11, 2015 | LG LED 22CV241-B Chromebase 22INCH...
Im locked out my dell inspiron 15 windows 8 how do
Procedure 1, Download and install the Windows 7 Password Recovery Tool from my now surfing computer via site:http://www.windowspasswordsrecovery.com
Procedure 2, Run the tool and burn iSO image file into a blank USB Flash Disk (Blank CD/DVD is also OK.) for creating a Windows 7 password reset disk.
Procedure 3, Do BIOS setting on locked Dell Windows 7 computer and set it start from burned USB disk.
Procedure 4, At last, restarts Dell pc and remove Windows 7 administrator password within clicks.
Oct 03, 2014 | Computers & Internet
My IBM computer doesn't recognize when I plug in the usb camera patch cord and even the display goes blank on the camera. So do I need a new driver or camera
Welcome to Fixya
Did you accidentally dropped the camera? You should be able to see options when you plug in the camera to your computer. Try to reset the camera first to factory state as part of our initial troubleshooting.See procedure below:
Select reset settings icon Press set button Reset setting screen should appear then press YES Press the SET button Camera setting should be reset then test the issue again
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jun 10, 2011 | Sanyo VPC-C5 Digital Camera
Got a dell latitude e6400series forgot bios password can i fix this problem ?
Welcome to Fixya
Common procedure in resetting the password is by resetting the motherboard by reseating the CMOS battery. You need to access you motherbard and locate the circular silver metallic object on the motherboard. This is much bigger in size compared to a wristwatch battery. CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. Put the the battery back in and turn on the computer.
Other procedure is the jumper reset. Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
If procedures above has been done and yet you are getting same results. Its time to call you manufacturer and have the motherboard re-flushed or re-imaged.
Mar 31, 2011 | Computers & Internet
How to rest to facory settings?
Hello Sir,
There can be 2 resets which can be done. The one is BIOS Reset and the Other is the OS Reset. If you want to get the Laptop to Factory settings then you have to do a OS Reset. For this you need to get the Operating System Recovery CD. Insert the CD and boot the CD. The Recovery Procedure will automatically start and the Computer will guide you through the rest of the Procedure. Follow the Computer's instructions and the laptop will be restored to Factory Settings. ' Reply me if you have any doubts or problems.
Thank you Sir, Have a nice day.
Oct 18, 2009 | Compaq Presario Notebook
D-524 wont reset and gets no\limited connectivity and...
Unplug the router from the computer.
Unplug also from the network
Reset the router alone (use the reset hole)
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
Connect the router to the computer only
You have to access to your router typing http://192.168.0.1 user= admin pass= blank (no password) this is a default settings.
Nov 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Hotpoint Aquarius WF220 Front Load Washer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
