Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Just installing the smartcode and have turned on the auto lock after 30 seconds but once locked it still tries to keep locking
Have the the 30 second auto lock on, when we close the door it automatically locks after the 30 seconds, but then keeps trying to lock again
4 Related Answers
Anonymous
  • 8 Answers
SOURCE: How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Posted on Jan 08, 2009
Anonymous
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
Anonymous
  • 3 Answers
SOURCE: our lock is in reverse, the lock opens the door
open the cover, move the jumper over.
Posted on Dec 02, 2009
seanpwright
Sean Wright
  • 2030 Answers
SOURCE: I programed the lock. It beeped in recognition of
if the batteries are new and good, sounds like a problem with the lock motor..is it a new unit? if so exchange it. try another set of batteries.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Feb 06, 2010
My 2001 ford focus keeps locking. The power locks automatically lock as soon as I unlock them, barely enough time to open door.
Your Focus may be equipped with the autolock feature. Try this:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Feb 18, 2015 | 2001 Ford Focus
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Oven door locked
Many Kenmore ovens have a control lock that keeps the oven door locked even when the self-clean cycle has not been in use. This feature is meant to prevent children from opening the door or using the controls on the oven. To cancel the oven lockout, push and hold "Stop" for three seconds. Wait 15 seconds for the oven door to unlock automatically.
Reset
After verifying that the oven lockout feature has been released and waiting at least an hour after a self-clean cycle, if the oven door remains locked, try to reset the oven. Disconnect power to the range, and wait 30 seconds. Restore power and try again. If the door remains locked, disconnect the power and try to reset the circuit breaker or fuse. Contact Kenmore if the door remains locked after both attempts at a power reset at 800-827-6655.
Feb 26, 2014 | Kitchen Ranges
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
2003 Tiburon power locks keep automatically lock
replace both door lock actuators to fix problem.
Aug 31, 2009 | 2003 Hyundai Tiburon
How do I reprogram the 2004 Pontiac Vibe key fob?
To begin programming, follow the procedure.
  1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
  2. Insert and remove the key from the ignition switch twice within 5 seconds.
  3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
  4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
  5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
  6. Remove the ignition key from the key cylinder.
  7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
  8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
  9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Jun 11, 2009 | 2003 Pontiac Vibe
Automatic Door Locks when you start driving
Yes, there is a way to reprogram your car to lock the doors when the gear selector is put into Drive.
Follow this site for a complete step by step re-program of the door locks:
http://www.nialtima.com/automatic_door_locks-113.html
Jan 23, 2018 | 2002 Nissan Altima
1999 Lincoln Town Car Cartier door locks
U may need to program the auto lock feature again, the instructions are this
Autolock can also be activated or deactivated using the following
procedure:
You must complete steps 1 through 7 within 30 seconds or the procedure
2. Press the power door unlock control on the door panel three times.
5. Turn the ignition key back to ON. The doors will lock and unlock.
6. Press the power door unlock control. The horn will chirp once upon
successful toggling of the Autolock feature.
7. Turn ignition to OFF.
May 15, 2009 | 1988 Lincoln Town Car
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
331 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
