Wired unit to thermostat and to 2 ton heat pump condenser low voltage r (hot) from condenser to stat to airhandler g (fan) stat to air handler green black. Y (cooling) stat to condenser white or O&B terminal white black w 1 on air handler and blue (L Honeywell stat) to brown (c) condenser and to (C) brown on transformer. blew a 20 amp fuse & had no power to stat. replaced fuse didn't check transformer to see if blown a inline fuse with spade connectors was also installed .I figured transformer was burnt any suggestions??????
SOURCE: wire size for a 2 ton gas pack
In door shod be #12 and out door shod be #10 if it is not that far from the box
SOURCE: Rheem furnace has 2 green lights 1 is slowly blinking
you can check the inside door chart, and it will map out the led light readout for you. just follow the instructions on the panel and it will tell you possible problems and what you may need to fix to make your unit run correctly.
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
