Question about Panasonic PT-47WX49 47" Rear Projection Television
How to dismantle a Panasonic 47Wx51E? - Panasonic PT-47WX49 47" Rear Projection Television
Panasonic tv PT-47WX51E has green vertical lines,how do I get them out?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Jul 27, 2015 | Panasonic Televison & Video
White substance inside lens
It is highly unlikely that anything has entered the lens.
You would not need to dismantle to clean.
Wipe clear with the lens from outside.
Wipe clear the eye piece as well.
Otherwise is the recording head that needs to be cleaned.
Apr 27, 2014 | Panasonic NV-GS17 Mini DV Digital...
My panasonic ceiling fan F-MY143, non-stop changing the speed automatically...what's the problem? how to solve?
Hi all,my Panasonic Ceiling Fan F-MY143 speed can't be control using remote controller. When remote controller is being pressed, led blinking and a beep sound can be heard. Pls help, thanks in advance.
Jan 04, 2012 | Panasonic Dryers
Can a blu ray dvd work with a panasonic pt-47wx51e?
Yes, you will need to hook it up just like a normal DVD.
If you can use the component inputs you will get a better picture.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Panasonic PT-47WX51 47" Rear Projection...
My panasonic tv pt-47wx51e color looks like 3d how can i fix this
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
Jun 26, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Jun 08, 2009 | Panasonic Room Air Conditioner CWXC104HU
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Replace conversion board
Signal / Main PC board AKA the "A" board is send for repair only = PTS corp ....Part # TNPH 0370.....250.00 Approx.
OR
Replace IC7001 & 7002....STK392-110 and inspect resistors.
If you have good electronic repair skills,you might attempt to
DIY...otherwise, hire a senior tech,if possible...............T.
Feb 06, 2008 | Televison & Video
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
