Question about Boating
6hp johnson outboard repair
Cranks good smooth idle speed will not will not open up under load extra smoke heavy oil on water in test tank. all elect. parts chk good
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
discodata
  • 11 Answers
SOURCE: My 1976 Johnson 6hp outboard idles OK,but won't
High speed jet in carb is blocked disassemble carb remove jets and dip jets and carb assm in carb cleaner ( it comes in a gallon can with a parts tray in the can ) available in most autoparts stores BEWARE remove all Rubber O-rings and gaskets before dipping let set overnite or a couple of hours then blow parts off and reassemble. as far as adjustment screws just turn then in until they stop and count the turns then remove them. When reassembleing just reverse the procedure insert turntil they stop then back them out the number of turns that you wrote down. I had to do this with a 1985 150hp V6 with six carbs and it fixed all my problems as well as a 1976 25hp Johnson. Good Luck
Posted on Aug 06, 2009
x1745
  • 40 Answers
SOURCE: 9.9 johnson 4 stroke wo'nt idle
Your cabs need rebuild, something is stuck in the carb or air line cracked
If you have rebuilt the carb check for carb gaskett leak that caused and let the air flow in
When to choke is on the air is block and prevent air flow but allowed small amount of air to keep the engine running
After your engine warmed up the heat in the compression burn much faster so you have to let air in by turn off the choke
Good luck
Posted on Aug 20, 2009
Joe Hogan
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
Anonymous
  • 14 Answers
SOURCE: Honda outboard four stroke misfiring?
I would take it right back to them. It is possible that the fuel lines were not changed or at least flushed before they put the new carbs on. It must have been in bad shape if you had to replace the carbs. Although, sometimes that is cheaper than a carb job.
If is very possible that some debris left in the fuel system or fuel pump that is caught in one or more of your carbs. It only takes one on a 25hp to make it run bad.
This sometimes happens even if the lines were flushed. I see it every once in a while. We try to catch it before it leaves by running it under a load at the water for a while to be sure everything is working right.
Since you put a water separating fuel filter on, it appears that there was a problem with water. Again if lines were not flushed, water could still be in the lines.
Before you take it back, drain each carburator into a glass jar and see what the fuel looks like. If it have water or debris it will settle to the bottom. If you find some, just flush the system until no more water or debris comes out. Then see how it runs.
You should always use some sort of fuel treatment like PRI-G or Sea Foam to keep the fuel fresh and to minimize the effect of the ethenal in the fuel.
Hopefully, the dealer can find the problem fast and at least give you a break on cost. We would normally do it for free if the customer brings it right back and it appears that we missed something.
Posted on Sep 17, 2009
Getting water in carbs not from fuel tank it happens when I put it in forward it's a 140 evinrude looper
Your engine should be sealed enough to prevent this..unless you have the engine mounted so low it idles under water...???.. There is a seal that goes between the lower cowl pieces and the engine, a seal around the engine cover(cowl)...and seals that surround all wires and cables.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Jul 14, 2017 | Boating
50 hp 4 stroke Johnson 2004 starts easy and idles smoothly.Runs very rough when speeding up.when changing oil in crankcase - no oil in oil filter.What happened?
First..
No oil in the oil filter period?? Does the opening of the oil filter face down.. like the oil will drain out if sitting still?
..You need to talk to a qualified professional.. this could be very serious or SOP..
Jul 08, 2017 | Boating
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Jun 09, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have a short shaft Johnson 6hp outboard, the Jon boat I mounted it on is too deep, and motor doesn't reach water. Is there a way to lower motor? A bracket to lower motor to reach water?
outboard motor manufacturers supply a long shaft leg for just this problem
Talk with your Johnson dealer and check used outboards on e bay
Lowering the whole motor may affect the boat and floatation aspects besides making it harder to steer and start
Apr 15, 2015 | Boating
1985 johnson 85 hp outboard bogs under load
CHECK IGNITION COIL OUT PUT AFTER THEY HEAT UP. A WIRE CONNECTION (INTERNAL) COULD BE SEPERATING, NOT MAKING CONTACT AFTER HEAT EXPANSION
Jul 23, 2013 | Boating
Excessive white smoke out of blow by
Just letting you know that white is water, blue is oil and black is gas coming out of the exhaust.
Jul 20, 2017 | Cars & Trucks
1994 90HP johnson outboard
Hi, your problem is simple you either have a head gasket gone or a exhaust plate/gasket gone. Either will let water into a cylinder which is why it ran ok without water. You should also check the water pump in the leg as you have now run it without water. Regards Phil.
Jun 20, 2012 | Boating
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
Sep 16, 2009 | Boating
My 1976 Johnson 6hp outboard idles OK,but won't rev up to power under load when I open the throttle. When I checked the spark pluge, I found the top one to be wet with fuel mix, but the bottom one was...
check for spark against the block. they sell a test kit, i think harbor freight sells one, where you hook it in line and should be able to see if it is firing or not.
Jul 29, 2009 | Boating
Boating Logo
169 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
